Question about Hotpoint Ultima WF860 Front Load Washer
Wt960 comming up test
  • AndyH2 Sep 16, 2008
    I have the WT960 machine and whatever we do the system just keeps running through the tESt routine. I have tried using the solution suggested but this does not take it out of Demo (Test) mode. Also tried the other suggested solutions but no joy.
    Went to the Hotpoint web site but could not find a solution to this problem.
    Any more solutions?
    Andrew
  • sherah693 Feb 22, 2009
    my wt960 keeps saying test help please
Now sorted. Called a service engineer! He tried just about every key combination going but nothing happened. He went off to investigate further and left the machine unplugged. Several hours later he rang back and asked me to use the StartCancel and OnOff buttons together and while holding them in also press the Spin button. The D Off message came up almost immediately. Apparently the secret appears to be to let the machine completely power off.
Andrew
Posted on Sep 18, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 27 Answers
The applionce is in demmo mode and running a test cycle so you need to cancle the cycle first by holding the start reset button until all the screen iluminates(88:88) now you need to disable the demo mode by holding the start cancle and the on off buttons together until you see D OFF in some cases you may need to hold the button to the top left of the screen and the start and on off buttons but this will sort it
Posted on Feb 22, 2008
  • 4 Answers
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
How do i reset my hotpiont ultima lcd wt960 washing machine?
I have a hotpoint wt960 i did 1 load of washing, turned it off. Put next load in then it would not turn back on. any ideas???
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 comes up with test all the time
Press the Start/Cancel button until all the console Led's Illuminate
Press both Start/Cancel and On/Off buttons together until 'd off' appears
Normal screen should return and you can select a new programme. (GL = good luck)
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wt960 keeps saying test HELP
turn the machine on whlile pressing the start and on buttons at the same time.hold until 'dOFF' appears.
Feb 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
Filter on WT960
hi, in the uk the filter is behind a flap on the bottom/front of the machine, be careful as when you undo it some water will leak out, hope this helps
Feb 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Does wt960 have an eco mode?
This model does not have a specfic energy save programme, however, by selecting a coolwash at 30oC or a mini load, you will use less energy.
These features are detailed in the user instructions.
Plz rate my solution.
Thankyou.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
May 25, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
205 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
