KV27TS30 Sony TV Problem determination (See Video enclosed)
Hi
My TV has been emmitting high frquency noises for many "Months" possible years. It has now started (After about 5 minutes of use) to have the video "flash" and it makes loud "Galloping sounds". I have posted a video on youtube where you can actually see the effects on the video and hear the sounds.
http://www.youtube.com/watch?v=df7a_peuv...
I am thinking that maybe it is the high voltage transformer, but am also concerned it may be the Picture Tube.....
Any ideas as to the Problem, Solution, and possible sosts to repair a problem such as this.
The TV is a Sony Model KV27TS30 purchased in 1989.
Still looks brand new.....
  • Ken Flack
    Ken Flack Feb 09, 2008
    Here is the video
Slinteriors
  • 8617 Answers
SOURCE: KV27TS30 Sony TV Problem (HV PS ?)
Your set isthe LN-1 chassis that problem is definately in the deflection / high voltage circuitry most likely the flyback itself. however this chassis has a history of bad solder cracks around the flyback and horizontal transformer mounting locations. I would check the solder before replacing the flyback. Also notethat if this condition has been ongoing without putting the set into protective shutdown you will also be looking at possibly having some weak regulator transistors and leaky diodes on the power supply module. Let me know if you need further info or a service manual for this set.
Posted on Feb 10, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung hl-s5087w noise problem
a growling sound can mean a defective light engine as there have been issues described a s a growl or groan sound when a light engine is defective
Posted on Jan 26, 2009
  • 1937 Answers
SOURCE: Washer won't agitate, but will drain. Loud cliking sound--VIDEO
This looks like a basic Kenmore / Whirlpool top load, direct drive, neutral drain washer.
Assuming that it won't agitate at all, but will pump, here are a couple of things to consider.
1. There is a motor coupling between the motor and transmission that is used as a fail safe. It has plastic pieces with three prongs on the transmission and motor shafts with a rubber coupling between them. If the rubber piece is broken or damaged, the transmission cannot turn the agitators or tub for spin mode. The pump is directly driven off the motor when is in reverse mode.
See the following Whirlpool document on installation and maintenance with a good troubleshooting guide.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the Sears parts site :
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of sub-components will come up. Check the section on motor and pump and you'll see the coupler.
2. Beyond the coupler (an easy fix) it could be the agitate cams and gears in the transmission.
If the washer spins I'd look at those or the Neutral Drain assembly in the transmission.
As for the pin, It is one of three shipping pins designed to break off and fall into a plastic cup under the tub when the washer is installed. I'd look under the tub and see if the pin is missing from one of the cups. If it is, it's nothing to be concerned about.
Posted on Sep 22, 2009
sloooo44
  • 235 Answers
SOURCE: My Fedders room A/C model a6u14wta is making weird
Could be your bearing are going bad on your indoor fan but you only hear the sound when you turn it. Could also be something hanging behind it and it only hits the fan when you turn it on high and it pulls it into the fan blades.
Posted on Sep 28, 2010
  • 60 Answers
SOURCE: The engine sounds very loud
The flex pipe is located towards the rear of the engine, under the vehicle. It will be very obvious, you mentioned it was loud as if missing the muffler and coming from the rear of the engine. That sounds like a flex pipe and/or front pipe problem.
Posted on Mar 05, 2011
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
Feb 17, 2012 | Sony Audio Players & Recorders
My Receiver is emmitting a loud high pitch hissing and cracking noise when volume is raised in Video 1 and Video 2. It is not the speakers as they all work and have the same noise coming out of...
This happens only in Video 1 or Video 2 using analog audio? Try using an HDMI cable or the digital input(optical or coaxial) cable and see if this issue is heard though these connections as well. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You can contact me through the website. Thank you.
Jun 04, 2011 | Sony DAV-FC9 System
I am getting standard definition but not hd
Is your TV capable of displaying high definition? Is it an HDTV? If so, go to the Settings on your XMB (Press the Home Button) and into the Settings menu. Look for the option which says Display Settings. This will guide you through the configuration wizard and determine the best possible output for your TV. If it doesn't output at least 720p then your TV is not capable of displaying high definition.
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My sharp aquos lc30 ad-1e won't turn on from standby.
hi you might have to contact the place where you bout the tv an let them kno your problem if they cant help you then call sharp and let them know your problem your tv is covered for one year so if you had your tv less than a year let them know that also
Jan 10, 2009 | Televison & Video
SONY KV-XF21N90 WON'T TURN ON, Blinks 5 times
5 times flashing light shows following possible problems in your tv..
• G2 is improperly adjusted.
• CRT problem.
• Video OUT IC1800 is faulty.(C5 board)
• IC301 is faulty. (A board)
Most probably cause is G2 voltage adjustment. If you know how to do it, please go ahead or look a tv tech around.
Regards,
Sep 04, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Feb 10, 2008 | Televison & Video
Q Box problem
wow, it just goes to show you that even big name brands have poor qc or qa on their products.
Jan 16, 2008 | Sony KDS-R50XBR1 50" HDTV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
