Question about Car Audio & Video
Cddj I took my 1999 ford expedtion in to get my heater fixed to the ford dealership. by the way... They had to pull my dash an my console. where my cd player is at. when i got it back i pushed the cd button to play a cd. an now it says. no cddj. they say it is not their problem. I really need help.
  • tgoltermann Jun 21, 2008
    cd player in 1999 ford explorer says nocddj
My 2000 expedtion cd changer just stop working.The display says "NOCDDJ".Don"t know why.
Posted on Feb 28, 2008
Where is the heater core located on 99 Ford escort ZX2?
Typically you will find the heater core sits inside the dash just inside the fire wall of the engine compartment, from the engine bay you can follow the water lines from the cooling system and water pump that go back to the fire wall and through to the heater core, find those to hoses together and the heater core is on the other side under the dash, usually under passenger side under dash behind the heater box, they are usually labor intensive to pull, and some require pulling the dash partly off etc.
Jun 17, 2015 | 1999 Ford Escort
Here we go again I have a 1999 ford expedtion with a heating problem I have heat for about a min or two and then gets cold both of the hoses on the heater core r hot changed the tgermastat the radiator...
three possibles, the control unit on the dash is not moving the blend door, the blend door motor is not working, the plastic blend door inside the same housing that the heater core is in, is broken.
Dec 13, 2010 | 1999 Ford Expedition
My 1997 ford expedtion is leaking water on the passerger side.. I can't find the leak.. when i turn my a/c on i smell the radiator and fogs up my windows when the heater is on. is my heater core bad? or a...
mcdevito75 here, Sounds like you have 2 problems First the water on the passeger side, it:"s most like luy a clogged drain for the A/C evaporator under the dash board, Check the drain hose on the firewal, just opposite the glove box, also if you can look under the dash on the pass. side and check the drain hose on the evaporatror. 2nd problem sounds like a bad heater core. Have your local shop check both these items for you
Jun 17, 2010 | 1997 Ford Expedition
1999 camry light behind the heater controls does not work
Your public library will have a manual covering your mechanical repair. Moreover, they have the automotive shops online software called AllData. It is the best auto technician database available today. You can print out specific troubleshooting procedures, diagrams, step-by-step istructions, and soforth. The typical person cannot afford to pay for this service, just automotive dealerships, etc... that is why the public library made it available to everyone and for free to view and print out material. This should Fixya! Good Luck!
Please rate my assistance.
Aug 14, 2009 | 1998 Toyota Camry
Cost to replace and repair heater core in 99 Grand Marquis
about $1200 US, this requires the dash be pulled out, about 12 hours of labor.
Mar 24, 2009 | 1999 Mercury Grand Marquis
I need the location of the A/C and Heater Blend Door Actuator
take abaut 5to6 h to fix it im dane so far10 of that,door is lokete bihaind dash on heaer and ac box and dash mast be remow to fix same.Good lack big jab to fix it
Mar 13, 2009 | 1996 Pontiac Grand Am
6 dsc changer stock radio 99 ford explorer cddj error
I've had GREAT success by resetting the changer. Try unpluging the changer with the power ON, wait a few, then plug back in. It's not hard to remove. Can I assume that you did NOT misload or install any CD' upside down? If not, then proceed with a reset. Can you eject the magazine? If so, proceed with reset. If you can NOT eject the magazine, then you will need to "open up the can" and do a manual eject with power assist by moving the gears while pushing the eject button. Sounds like a lot, but for me it's easy. Remember patience!!
Larry T
Winona Lae, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Pioneer DEH-P6800MP CD Player
Replace bulb in the a/c heater control panel
no pull the plastic lego kit up and that leaves eight 7 mm bolts
Jan 08, 2009 | 2000 Ford Expedition
My 1999 Ford F150 Heater only blows out cold air
guys have you checked for a vaccum leak????? there is a little plastic ball with a vaccum line going to it that controls the outside air coming in. check for a leak in this line
Dec 10, 2008 | 2001 Ford F150 Styleside SuperCrew
Car Audio & Video Logo
317 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
