Question about Panasonic PT-47WX42 47" Rear Projection Television
PT-47wx42 color problems
The only problem I am having is a transparent blue and green below the blue curving across the top and bottom of screen. Kind of looks like a someone took a spray can of blue and sprayed it across the top and bottom of screen except it looks like a wave on both bottom and top of screen. The strip of blue is about 5 inches wide and the green following just below the blue is about the same size.
I tried the convergence 1 (lined it up to hash marks on TV and went thru the other colors and lined them up) and 2 and it is most evident on convergence # 2 that the blue will not line up with cross marks. I tried the #2 convergence but no matter what the blue will not line up with the hash marks. The blue is high on the upper left hand corner (the hash mark is yellow). The blue is also hign on the upper right hand corner. The lower left hand corner is high and the center bottom is slightly high. It is as close I as can get them by convergence.
Help, how do I align these colors that just went bad one day? Thanks
My email is donla@adelphia.net
  • donla Feb 09, 2008
    The TV is about 5 years old and the blue and green problem is transparent. The rest of the picture is fine, just these stationary waves of blue mainly and the green below it. Thank you
    Novelist:
  • 123 Answers
Hi
 Resolder the Thermal Deguassing Cube. It is usually Black, about 3/4 inch cube and will be located close to the deguassing coil plug coming from around the Picture Tube
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 09, 2008
  • 1 more comment
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 09, 2008
    There are so many possibilities. It could be a dead projector tube, leaking cooler fluids, bad power supply connection, broken connector pin and so on. You really need someone who can get inside and find out the cause of failure; it requires one who knows how to observe, take measurements
    and track down the various possibilities. It is not an easy job on this one and it is not a home remedy solution, sorry to say.
    For the beginner, here are two things you can do - and they don't cost anything.
    ONE: Do a hard reset. Unplug the power cord for 4 full hours, then power it up again.
    TWO: Give it the banging test. Smack the set vigorously with your hand or fist in various places. Doing so will often reactivate a loose connection or cold solder joint. This may bring the red gun back to life - let's give it a 35% chance of doing so.
    If these two procedures don't help you are going to have to bring in the big guns.
    Just a comment: There are over 3,000 parts in a set of this kind not counting themillions of transistors buried inside the several integrated circuits. There are about 12 totally independent sections that function on their own as well as interface
    with all the other circuits. It is not something easy to do. Even a trained and experienced PHD in Electrical Engineering does not have the foggiest idea about what goes on inside a tv without extensive training in television receiver theory and practice.
    So, don't feel overcome with it all; there are few who really know this business.IT is truly esoteric in nature.
    Good Luck
    You may want to try purchasing a video test tape with color bars and this tape will also have a test pattern for all red screen, all green and all blue. With this you should be able to determine if the picture tube is weak or a fault with the color drive circuits is at hand. You will need the color bars on the screen to adjust the tint control from left to right fully to see if the three colors will show up.
    Good Luck
    The solution and comennnt will solve your problems
    Genius:
  • 3,422 Answers
This could be a heater-cathode (H-K) short in the CRT, a failure of a component in the chroma circuits or video output (driver board), or bad connections there or elsewhere. Don't panic - heater-cathode shorts in CRTs can often be worked around.
Note: before proceeding, it is a good idea to make sure that the screen is degaussed - else you could be attempting to track down problems with the wrong color!
Some simple tests can confirm or rule out other possibilities.
  • Compare the voltages for the video drive signals to the CRT on the little board on the neck of the CRT with the CRT both connected and unplugged. A schematic will help greatly in locating these signals.
    • If there is a significant difference especially on the bad color, then the CRT is a likely candidate. Try tapping the neck of the CRT GENTLY (with it plugged in and while viewing a picture) to see if it is an intermittent problem.
    • If there is no significant difference, you may have a bad driver or a problem in the chroma circuits.
  • Look for bad connection/cold solder joints, probably on the little board on the neck of the CRT. Use an insulated stick to gently prod the board and its components in an effort to induce/cure the problem. Look carefully for hairline cracks around the component leads.
  • You can swap components between two colors and/or test with an ohmmeter on that driver board to determine what is bad. The nice thing about color monitors and TVs is that there three copies of each of these components. Swapping and/or comparisons between these is an excellent diagnostic technique.
  • Another simple test: Disconnect the cathode for the full-on color from its drive. If it is still full-on, there is probably an H-K short in the CRT since the only way to get each color on the screen is via the cathode connection to the CRT neck board. If it is removed and there is still that color, the current must be taking another path inside the CRT.
  • Alternatively, interchange the outputs of the bad color with a good one by jumpering on the video driver board (on the CRT neck). If the bad color changes, then the problem is in the circuitry and not the CRT.
So you have to get a tech if the above method doesn't solve your problem and get it fixed..
Goodluck,
Please don't forget tor ate me as fixya..
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Pcture problem
Replace both STK392-110 convergence IC's with Toshiba or
Sanyo brand...............no cheap junk !!.............T.
Aug 04, 2008 | Toshiba 43H71 43" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic- 47wx42f
the convergence ic's are at fault need replacing,call a service shop and ask for estimate to repair .should be under $ 300.
Dec 09, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
47wx42 - wavy red and green "bars" on top and bottom of screen
Replacing the two STK392-110 ICs didn't do it for me. But you can try. I am experiencing the same problem, and it appears that is not possible to correct the problem with the ajustments in Service Mode. Please let me know if you find a solution to this problem. TIA.
Aug 30, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
