Question about Black & Decker B2000 Bread Maker
Breadmaker Won't Start
I'm trying to use my B&D B2300 for the first time. I have followed all the directions and made all selections required for the "basic" setting. I then turn the power "ON" and I wait. The screen shows "3:30" and counts down with the colon flashing. After 45 minutes, nothing has happened. What is the problem?
  • bunn864 Feb 09, 2008
    I've had my bread machine since just before xmas, have used daily if not every other day with no problems, now all of a sudder I am getting the same problem. Timer starts but it doesn't do anything other than count down, beep when time to add more ingredients.. but thats it. any ideas?
I tried my regular bread setting like I said I was going to in the previous solution and it worked. Here are the steps that I did. Put pan in machine, plugged unit in, set my loaf for 2.5 lb, set light setting. I checked machine setting and it said 3:30. Then I went to the delay start and it said 13:30 which meant that it would not be ready for thirteen hours, so I decreased the time to 3:30. Then I hit the start button so that the : display started blinking. The machine started counting down and I expected it to turn on at 3:15 but it did not turn on until 3:10. (I think the factory setting has been set wrong on my machine and always has a delay start of thirteen hours instead of on delay at all. I hope this helps you.
Posted on Feb 24, 2008
I had the same problem. Check the delay start button even though it doesn't tell you to. To get my machine to work the first time I used Menu #3 (which does not have a delay start) and it worked. Then I tried to use the dough cycle and it wouldn't go either, so I unplugged the machine, plugged it back in, went to Menu # 3 first to see the time (which was 1:50) then I checked the delay time to make sure it was also set at 1:50. Mine was not (it said 2:00) so I moved it down to 1:50 and it started 15 minutes later. I really don't like this 15 minute delay on this machine. I am going to try regular bread later and I will make sure that the delay time is the same as the time given for completing the loaf ( ie make sure it says 3:30 NOT 13:30. I hope this works.
I have a Breadman TR875 breadmaker. It will not do anything when I hit start. I've tried to unplug it, but didn't help.
I believe for this perticular model to power-up, you must press the Select button first to select a mode, then press the Start button.
Here's more on the subject...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source your accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reset the breadmaker by pressing down on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Note: It bears mentioning again at this point that some models require you press the Select button first to select a mode, then press the Start button.
Jun 20, 2011 | Breadman Kitchen Appliances - Others
My b2300 bread maker wont start on the 15 min delay after i push the start button .......why? i hate this machine and wont recommend one to anyone.......love my old sunbeam machine which just broke down...
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 19, 2011 | Black & Decker B2300 Bread Machine
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
Breadman Pro TR875 is stuck & will not start up to knead the dough. Timer is hi-lighted & shouldn't be. No pushing of any buttons will not clear & start over
  2. Confirm the power source you're drawing from is live using a blender, toaster, etc.
  3. Plug the breadmaker in, unplug it, then plug it in a second time.
    4. Some models require you press down on the Stop button until the unit powers up.
E. Some models require you press down on the Start button until the unit powers up.
F. Some models require you press down on the Select button until the unit powers up.
G. Some models require you press the Select button first before pressing the Start button.
In the end, were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Have the breadmaker serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the breadmaker's electronics by pressing down on the Stop button until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press down on the Start button instead. And yet a few others require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. r53w6t
Jun 07, 2011 | Breadman TR900S Bread Maker
West Bend Bread Maker model 41056 does not start. When machine is plugged in, LED displays a time but buttons do not work and red light does not go on. (Pan was in machine and anchored.)
Power-Up/Start-Up Issues:
    1. Some models have a built-in off/on toggle power switch. Be sure it's turned on.
    2. Most models confirm power by making an audible beep when plugged in.
    3. Most models have a colored light and/or a lighted display screen that lights up.
    4. Most models require you press down on the Stop button until the unit powers up.
G. Many models require you select a baking mode by pressing the Select button before the pressing the Start button.
Q: In the end, were you able to confirm your breadmaker is receiving power?
No. Sorry to hear that. Have it serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the electronics by pressing down on the Stop button for 1 to 5 seconds. Note: A few models require you press down on the Start button instead. And even fewer require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. See reboot directions above.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. 465ygbea
Jun 07, 2011 | West Bend 41053 Bread & Dough Maker
How do I start the bread machine, I've followed all instructions but the machine just beeps and beeps for a long time until we unplug it
Use and Care Book for the Black& Decker All-In-One Horizontal Deluxe Automatic Breadmaker is here:
http://useandcaremanuals.com/pdf/B2300UC.pdf
It sounds like a programming error. Be sure you all following the setting and programming instructions completely and that the breadpan is propely seated in the unit.
Mar 13, 2011 | Black & Decker B2300 Bread Machine
B2300 breadmaker
I had the same problem and what you need to do is hold the start button down for 3 seconds and that will clear the default setting (1 3:30). Then select the settings you need starting with the program setting for your recipe (i.e. #4 for sandwich bread). Bear in mind that you may not be able to select your crust light/dark option for some recipes, but will be able to select the loaf size. I assume this is because the recipe program (i.e. #4 for sandwich loaf) is already prescribed in the setting. When you have all of your selections then press your start button, but don't hold it down for longer than a second because it will clear everything and you will have to start again from step 1. Good luck!
Dec 17, 2008 | Black & Decker B2300 Bread Machine
Need paddle to breadmaker.
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Nov 22, 2008 | Black & Decker B2300 Bread Machine
Breadmaker B2300 won't even turn on at all
Sound like your heating element got toasted. You one of two options, try repair it yourself or send it to service center to get it repair. If you decide to repair it yourself just visit your nearest service center, and take the following information; model # , serial #, and brand. There you will get all the information you need to get it up and running again.
Good luck,
Spur21
Jan 02, 2008 | Black & Decker B2000 Bread Maker
Kitchen Appliances - Others Logo
2,856 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
