Lexmark x1100 install failure
We have recently swapped computers and added a second hard drive. The install disk is not available and I keep getting the "spooler subsystem app" failure. I looked that up online and did everything it said. however I was missing the "version x" it talked about. I then tried to download a driver for the printer thinking that would solve the problem and I am still nowhere closer. any suggestions?
  • kauaikiki Mar 11, 2008
    Bought a new computer but using the same printer Lexmark x1100. Tried downloading driver. My computer is Vista. Is Vista compatible with my printer?
  • 96 Answers
Try deleting the existing printer and adding one back using the drivers below
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=37:1:0:4:0:0
Posted on Feb 09, 2008
IIT IS SHOWING SMART FAILURE PREDICTED ON HARD DISK 2 THEN AFTER TRYING TO START IT SAID CRITICAL REPLACE HARD DISC DRIVE
HI There, you have hardware monitoring enabled (which ever vendor software you are using).
This error states there has been too many read/write errors. The disk is coping by writing to another area of disk, however it is confirming you WILL need to replace the drive in a controlled manner before the disks dies. Then this is uncontrolled and risk data loss.
if disk mirror or using raid 5, just swap out the faulty disk.
If it is the ONLY disk or no raid disk sets involved.
MUST backup your data.
Swap the faulty disk.
Rebuild and/or restore your data from your most recent backups. good luck...
Sep 28, 2010 | E-Machines -T1840-CELERON-1.8GHz,40GB...
Will x1100 disk set my x1270 printer up
The Lexmark X1100 disk is not intended to install a Lexmark X1270 printer. Click on this link to the available Lexmark X1270 drivers: http://bit.ly/9Xw7bN. Choose the correct driver compatible with your computer's operating system. Download, execute the file and follow the instructions in the software. If you need further assistance, you can also contact Lexmark technical support.
Sep 14, 2010 | Lexmark X1270 All-In-One InkJet Printer
How do i download ocr for lexmark x1100 for vista i have lost cd
The Lexmark OCR software can only be installed using the installation disk that came with the printer. It's not available for download online. If you don't have it or you lost it, I strongly suggest you contact Lexmark technical support for assistance. Thanks.
Aug 17, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Hi I AM TRYING TO INSTALL A LEMARK X1100 PRINTER ON MY NEW COMPUTER.WHEN I PUT IN THE DISK IT SAYS NOT AVAILABLE IN ENGLISH.MY COMPUTER OPERATES WINDOWS 7.
go to the lexmark website and download the latest drivers for your printer and OS make sure it is in English language install it then plug your printer into the usb port and it should find the new hardware and finish installing the driver for it
Apr 03, 2010 | Office Equipment & Supplies
Server XSeries 220
Yes, that is the total amount of hard drive space.
This server was built for speed not for storage.
The xSeries 220 server supports four SCSI hard disk drives. The server does not support IDE hard disk drives. Some models support hot-swap hard disk drives and other models support only non-hot-swap hard disk
drives.
Your server supports four 1-inch (26 mm) slim, 3.5-inch SCSI hard disk drives in the hard disk drive bays. You can install four non-hot-swap hard
disk drives in the models that have the standard non-hot-swap drive cage. You can install three hot-swap hard disk drives and one on-hot-swap hard disk drive in the models that come with the hot-swap drive cage. Both the non-hot-swap and hot-swap drive cages hold a maximum of three hard disk drives.
The calculation at that time was 4 drives with 36.7GB storage.
Even if you find the drives somewhere, they will be very pricy.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 28, 2009 | IBM xSeries 220 (86451SF) Server
Boot failure Asus P5Q-EM
Disk boot failure. Issue:Disk boot failure.
Cause: This issue could be caused by any of the below possibilities.
  1. Boot options are not set properly in CMOS
  2. Non bootable disc or USB in computer
  3. Remove added hardware /check connections
  4. Hard disk drive is bad
Solution:Boot options are not set properly in CMOS
Verify that the boot options within CMOS are set properly. Below is an example of how we recommend the boot options be set. Additional information about how to enter CMOS can be found on document CH00192.
  1. Floppy drive
  2. CD-ROM drive
  3. Hard Drive
  4. Other / Network
Non-bootable floppy diskette or disc or USB in computer
Verify that there is no floppy diskette or disc in the computer. If the boot options are set improperly the computer could be trying to boot from the disc drive instead of the hard drive.
In addition to verifying there is no disc in the computer make sure that no USB jump drive, external hard disk drive, or memory stick is inside any memory card reader.
If you're wanting to boot from a floppy diskette, CD, DVD, or USB drive and are getting this error message and have verified that your CMOS settings are in the proper order as explained in the above paragraph the diskette or disc you're using is either bad or does not have the proper files on it to make it bootable.
  • Additional information about how to make a boot disk can be found on our boot disk help page.
  • See document CH000669 for information about creating a bootable disc.
Remove added hardware / check connections
If you've recently installed any new hardware it's suggested that it be removed to verify it's not causing this issue. If after the device has been removed the computer works and it was another IDE / EIDE device ensure that the jumpers are properly set on the hard disk drive.
In addition to removing any new hardware it's also suggested if you've recently moved the computer or installed anything inside the computer that the connections for the drive be checked. Usually it's best to simply disconnect the cables from the back of the drive and reconnect them to make sure they're connected properly. While inside also disconnect and reconnect the cable connected to the motherboard as well. While inside your computer make sure you're aware of ESD.
Bad hard disk drive
If you have followed the above steps and you continue to experience the same issue, unfortunately it is likely that the hard disk drive is bad or the controller is bad.
If available, you may want to connect another known good hard disk drive to the computer to determine if it can be detected. If it is able to be detected then replace your hard disk drive. If it is not detected, unfortunately you will need to replace the motherboard or controller as it is bad.
If no additional hard disk drive is available it is recommended that the hard disk drive be replaced first or that the computer be serviced / repaired.
Jul 01, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
Printer installation
Hi Roger22
you can find a complete .pdf guide thats easy to understand by clicking the link below !
Lexmark X1100 series User Guide.pdf
Worry not , the X1100 series should match your x1150 model installation procedure!
Whatever O/S you use , you can get the Lexmark drivers to match from the Lexmark downloads section for X1100 series below ( also links to other models as well !)
Lexmark X1150 drivers & downloads / Choose your O/S
May 22, 2008 | Lexmark X1150 All-In-One InkJet Printer
Purchased a lexmark X1150 printer that was kept in the box until recently unpacked to find out the disk and user guide sent is for an X1100 series. How do we get the right software needed to program...
Here is a link to download what you should have gotten on the CD.
Just choose the Operating System you are running
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X1150
Hope this helps
Thanks for reading!
May 02, 2008 | Office Equipment & Supplies
202 people viewed this question
jasbo
jasbo
