Question about Pioneer VSX-D514 Receiver
Input source switches automatically on my receiver
Greetings all,
I own a VSX-D514, had it for 3 1/2 years so far without any problems. Now, this problem started a month ago and got worse and worse this week. The amplifier constantly switches between inputs e.g., if it is set to TV, then, all of a sudden, it'll switch to VCR, or DVD, whatever. Randomly. Sometimes, it switches between Stereo and 5.1 audio, etc. It can start after 2 minutes, after an hour, not do it for 2 hours, etc. No cold or heat related.
I did the following to troubleshoot it:
1) Changed the batteries in the remote. Didn't help.
2) Removed the batteries from the remote. Didn't help.
3) Put the remote outside the house (no kidding!). Didn't help.
4) Put black tape on the infrared sensor window to block any noise coming into it. Didn't help.
I'm at the point where I sent it to get an evaluation on the cause of the problem (already, this will cost 35$).
Anyone ever had a similar problem? Any clue?
I googled the problem, that's when I came across this great site.
Thanks in advance for your thoughts,
Paul Belanger
belangerpaul@hotmail.com
    Problem Solver:
  • 6 Answers
Sounds like a short in the receiver itself.
definitely an electrical problem.
Posted on Aug 05, 2008
Could it bew heat related?
Volume goes up and down by itself
Hi wally,
It is sad your having a problem with volume automatically increases
and decreases without any manual input.
These could be caused either by a component on the circuits
( front panel), a faulty regulator or microprocessor.
Components :
can be such as tact switches , diodes
PCB foil tracks, connectors. These means it may needs servicing.
Start with the basics, take out batteries from the remote, and see
if it affects the receiver volume or the one causing the problem.
If the symptoms still persist, One may have to open it up.
and check on it.Have a tech to guide you if you feel you can DIY.
One of the ways to tackle these problem is to take out the
tact switches , or have it disconnected . And use the remote
volume control to adjust the main volume.
If these works for a day or two, find or order replacements
for the said bad components.
There might be other ways but that is what Tech are for.
Let us know what you find , or needs further assistance.
Oct 29, 2012 | Pioneer Vsx-d811s Audio Video Multi-...
7 year old Pioneer VSX-D1011-s. Looses settings after power off (ie switch off at socket) unit normally is in standby mode but if the power switch on the front or at plug (obviously!!) is turned off ...
As a pioneer dealer, I am well aware of this problem. Sadly, there is no consumer level fix for this problem. A special capacitive battery is soldered on the board, and will require a professional electronic repair person to fix.
Another solution is to purchase a battery backup (UPS) and plug the receiver into it. In theory, this would allow you to continue using the receiver with no loss of power ever.
May 04, 2011 | Pioneer VSX-D1011 7.1 Channels Receiver
Vsx-815h,power on hear the click as normal but no sound from any sources.The hdmi is allowing pictures so that side is ok.Has happened before and i left it unplugged from the mains for a short time and it...
Hello
At first check does the amp tunes to radio stations and can you hear sound from it. Your amp has no HDMI input function. The setup may have changed to your DVD or Blu-Ray player. Without knowing the device you connected to it, it is difficult to point out the exact fault. Anyway , just try these as your amps' maual indicates.
The user manul of your set points out these reasons only for absence of sound with your amp.
Go to the signal select setup and select "Auto" there. If it is selected to AUTO mode when you input a digital signal or analogue signal, the set will detect it automatically.
check whether MUTE finction is ON. If it is ON, turn it to OFF.
Check the speaker select function.
OK
Apr 12, 2011 | Pioneer VSX-815-K Receiver
Nead a remote and book and where do i plug my computer in vsx-90txv 7.11080p elite pioneer how much and where do i get it
Your PC can be connected like any other digital or analog audio source within its sound connection capabilities to any compatible input on the VSX. Just make sure you enable the PC's audio outputs and raise the volume.
Apr 08, 2011 | Pioneer VSX-90TXV Receiver
Volume changes automatically
Just a wild guess.
Does this receiver have line-of-sight with windows? Some other Infra-Red source in or out of your home may be affecting it. Try covering the IR 'eye' on the receiver to see if it stops happening.
I have an IR on my Media Center PC and the l.e.d. on it will light up whenever it receives a command, no matter what remote I use. Of course, it doesn't actually do anything unless I use its remote. Occasionally, it will blink even when I'm not using any remotes, so clearly it is seeing IR from somewhere.
May 07, 2010 | Pioneer VSX-D509S Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
Pioneer vsx d608-no sound
this is an IC failing , it changes the pre amplified audio to the amp.but there is most likely something causing this failure as well ,to much voltage to the chip , it will need testing
Dec 10, 2008 | Pioneer VSX-D608 Receiver
Receiver to tv hook-up
Is this a Pioneer receiver? They have the prefix of VSX but I can not locate that model on Pioneers website. It could be because it is an older model and no service information is on the website for receivers older than about 5 years old.
To answer your question I need more information. Do you want to connect the video switching of the receiver to the TV or just want the sound of the TV to go to the receiver? I would also need to know what type of video devices you want to connect and what type of inputs and outputs your TV has.
Most TV's have at least a composite video input, that is the most common type. it is a yellow RCA jack on the back of the TV and will be listed as an "input". That is what would be connected to the video output jack (yellow RCA) of the receiver from the TV for video switching. Then you need video sources connected to the video inputs of the receiver to go to the TV. You also need to connect the audio RCA cables from the video devices to the receiver on the proper video inputs that you have connected. Each video input for composite or S-video has audio RCA jacks (red and white) inputs so you can hear the sound of your video device on the receiver.
If you only want to play the sound from your TV on the recevier, you can use the audio output RCA jacks on the TV and connect them to an audio input of the receiver. This is a very simple way of using the receiver for all the different devices connected to the TV without having to connect everything to the receiver and then always having to have the receiver on any time you watch TV. The audio RCA jacks are always the red and white jacks. you just need to make sure you are using the output jacks of the TV and they are connected to an input jack on the receiver. Then you must switch the receiver to what ever input you just connected the TV to, like the "Video 1" or "Video 2" or maybe "Aux" input.
I hope this helps, but you didn't give much information on how you wanted to connect them.
A good rating would be appreciated if you found this free information helpful.
Let me know if you need any more help,
Dave
Jul 06, 2008 | Audio Players & Recorders
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
Pioneer VSX-D514 Receiver Logo
170 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
