Question about Bugaboo Cameleon Jogger
Loose brake on left wheel
I've noticed that when the brake is engaged, the left wheel brake doesn't completely lock the wheel in place.  In fact, it's quite easy to move it.  Is there something I can tighten or replace to fix this?
You can adjust the tension in the brake cable, there are instructions in the manual. Also check that you have the brake handle in it's furthest position. It can be quite stiff and takes a bit of force (especially if new) but it may go one click more than you currently have it.
Posted on Mar 06, 2008
Driver's side rear brake or wheel seems to lock up for short bursts while at low speed only noticed on a left forward turn into a parking spot.96 Chevy Z71 4x4
possible limited diff action making both rear wheels drive
wheel bearing failure or adjustment
brake drum or wheel loose on studs
Jul 31, 2017 | Cars & Trucks
Turn off the brake
If you remove the handle, you will notice there is one larger black Phillips screw under the black plastic strip.
Engage the wheels and loosen that screw.
Slide the lower handle part back and forth and you will notice the wheels will reverse and go forward again.
Find the position where the wheels lock and unlock for you, and tighten that one screw again.
It does not take very much adjustment to make that system engage so do it in small increments.
You will see what I mean when you unlock that screw and slide the lower handle just a tad , but the wheels must be in the engaged position in order to adjust it properly.
Hope this helps!
William R!
Oct 13, 2014 | Kirby Vacuums
4wd will not power front wheels
The fact that the service 4wd light comes on is good. That gives us something to go on. Did you have the 4wd trouble codes retreaved? If you tell us what the codes are we can go from there
Feb 02, 2014 | 2001 Chevrolet Silverado 2500
07 mazda front end scraping noise
First place to check is front wheel bearing loose or failed completely. Is the car at correct ride height and ar you running fat tyres. all of which allows the typr to hit the mudguard on lock.
Mar 10, 2013 | Cars & Trucks
Oldsmobile Silhouette possible problem(s), just questions currently.
First & only suggestion I have, is get rid of it, and any van type vehicle
They all are unsafe in an accident
Having once owned a trans repair shop, I will tell you they all have bad
transaxles & that is what you have
It is tens years old,the trans was done no matter what vehicle you bought
You mentioned water in headlight & more issues
That vehicle is going to cost too much to straighten out --- UNLESS
you do (100%) 100% of ALL WORK yourself & the trans is not something you can do yourself or even install one
Feb 12, 2013 | 2003 Oldsmobile Silhouette
I've 2000 Mercedes Benz ML 320.One night I backed up & parked in the Garage the next morning it won't go forward. I noticed the that REAR WHEEL on passenger side was locked up. What's
The only suggestion is to place the vehicle on
stands & remove the wheel to check out the issue
To speculate from the internet-- is just that.
To have something happen while you sleep
is odd,so I would be inclined to go with something
like an electronic parking brake issue,if that applies
Nov 14, 2012 | 2004 Kia Sedona
My 1992 Honda Accord sat for awhile and now the left rear wheel is locked up. Any thoughts. Thank you.
Your car has drum brakes on the rear. Did you have the parking brake engaged during the time it sat? If so the parking brake lever probably rusted in place. You might be able to loosen the cable at the drum. Otherwise, you need to remove the wheel and drum to free up the parking brake.
Jul 08, 2011 | 1992 Honda Accord
My front wells do not working 4x4
check you fuses for a blown fuse for the switch and relay that you enage the 4 wheel drive with, check the wiring to it to make sure that it is not unplugged....
Feb 19, 2010 | 2001 Kia Sportage
Left front wheel wobbles when braking
have you checked the wheel bearings? with that wheel raised up off the ground with a jack and on a jack stand, place your hands at the sides of the tire and give it a shake, do the same with your hands at like the 3 o clock and 10 o clock position as to not get your hand hurt if something moves loose, and shake there to, if you feel any play it could be a tie rod, or control arm, spin the tire and listen for any noise, if you hear any you more then likely have a bad bearing....
Jul 27, 2009 | 1990 Honda Accord
1996 Explorer is similar
It may be a calibration issue. The sensor doesn't know what is considered slow or stop., Yes,your right, a computer thing.
Jul 12, 2009 | 2001 Audi S4
Bugaboo Cameleon Jogger Logo
259 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
