I just receved a used yamaha A-320 amplifier
Seems like it keeps freezing up, Hook up tuner to it and Cd player to it, I get a slite sound can you help me?
  • 1,512 Answers
Check around the power supply for the dreaded holdown glue. It changes colour when heated(and blackens) and eventually begins to conduct. It is also very corrosive to copper bits, so scraping it away, can expose greater damage, If you see any sign of this, 9 times out if 10 it is that darn holddown glue. upseting the amp.
A"fixYa" rating from you for this advice will help my profile along.
regards
Graeme
Posted on Feb 09, 2008
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
I have an old Yamaha amp which has not been used for 15 years & it now keeps turning the sound on &off
If the unit has sat that long chances are capacitor replacements are in order, overtime they deform until they become unusuable and can rupture when power is applied.
Aug 31, 2012 | Yamaha Audio Players & Recorders
My Apline CDA-9831 has no sound when trying to play regular store bought CD's. It dose have sound on Tuner.
Are you using an amplifier? If so, make sure you are using the blue/white wire (amplifier remote turn on) instead of the blue (power antenna remote turn on) to turn your amplifier on. The blue wire turns off when leaving tuner mode.
Jun 28, 2011 | Alpine CDA-9831 CD Player
How do you hook up speakers on pioneer tuner f-9
You cannot hook up speakers to the F-9 directly because is has no built in amplifier. It has only a preamplifier out. You will have to hook up this F9 tuner to an Amplifier's Tuner/Aux input using a RCA cable. The Amplifier out should be connected to the speakers and when you select the appropriate input on the Amp you will hear your Tuner sound.
Mar 31, 2011 | Pioneer Audio Players & Recorders
Cd player cuts out when you insert a cd into player
do you mean the sound turns off when a cd is inserted into the deck? are you running your audio through and amplifier? if you are using an amplifier, you are probably using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remoter turn on) to turn the amplifier on. the blue wire turns off when you are not in tuner mode.
Jan 28, 2011 | Alpine CDA-9851 CD Player
Cant figure how to hook my stereo up
what to remember is pre-amp is before the amplifier then the amplifier to the speakers, go this route, Tuner for radio? from the radio tuner out go to the pre-amp tuner input, then from the pre-amp OUT go to the AMPLIFIER IN, tuner, cd, dvd, tv, any source, if you are using a 2 channel amp and pre-amp this is relatively easy, a little more detailed for multi-channel pre-amps and amps but follow the same path, sound source signal ie. tuner to pre-amp, pre-amp out to amplifier and speaker hookup to amp channels,
Jan 29, 2009 | Audio Players & Recorders
Sonance 275 no getting sound to speakers
The Sonamp 275 has Signal LEDs on the front panel, above the Volume pots. If signal is present at the RCA inputs, the Signal LEDs will be blinking.
Most likely, there isn't any line level audio signal coming from the receiver. Hook RCAs to Tape Output or MD output and check system using the Tuner which is an analog signal.
Jan 11, 2009 | Sonance SAT275 2-Channel Amplifier
Kenwood kdc-x592 No sound on CD and..
your amp turn on is hooked to the power antenna wire. Swap the blue wires and youll be good to go. Since the power antenna is not needed, when the radio goes off tuner, the 12V signal is turned off. and your amplifier will also then lose its remote turn on.
Reverse the 2 blue wires.
Dec 28, 2008 | Kenwood KDC-X590 CD Player
Getting occasional popping sound through speakers. My system consists of preamp, amp, turntable, tuner and cd player. It seems to happen when only using cd player. Hasn't happened when using only tuner or...
Describe your system in greater detail. Does the preamp have a mechanical selector for the tuner/phono/CD or does it have a digital selector that you can operate with a remote? The problem might just be a dirty selector switch that need to be sprayed with Deoxit contact cleaner. It could also be bad cables so try swapping cables with the tuner.
Dec 20, 2008 | Audio Players & Recorders
941 people viewed this question
 Grubhead
Grubhead
