Question about Maytag Performa PAV2200
When washing a load, it made a wierd noise then smoke came out.
I believe something caught fire because it was a LOT of smoke. I unplugged it and vented my laundry room. I haven't tried to use it again.
  • 240 Answers
Unplug your unit then tilt it back. Check your belt to be sure it didnt pop and get hung up in the motor assembly. If belt seems ok, look at the main drive pully, see if it turns freely. If not, the brake assembly or transmission may have went bad, and you will need special tools to remove it. Do not try to take apart brake assembly, it will pop off and injure (people have actually been seriously hurt, and have heard of a death or two) you. Let me know what you find out, and will go from there. Thanks!!!!!
Posted on Feb 09, 2008
Sound when it spins that sounds litle bearings
Check for something caught in the inner bowl. Check with torch if something caught between inner & outer bowl. Check main bearing, main bearing noise is usally associate with leaking water.
Dec 19, 2013 | Haier HLP21E Top Load Washer
My washer is giving out sparks from underneath when the drum is spinning. What causes this and could I finish doing the load inside safely.
Sparks?
No do not finish the wash.This could be a shorted electrical wire or motor.Unplug the washer.Remove the wet wash and put it in the bath tub for now.
You will need to siphon out the water or remove it by bucket.Continuing the wash could lead to electric shock or a fire.
This happend to me 12 yrs ago and the washer caught fire.it was a bad motor and the grease caught fire under it.
May 10, 2011 | Hoover HW5 513M Front Load Washer / Dryer
My dryer was smoking.... i unpluged it, can you give me a possible reason why? it is about 3 years old and is a stackable heavy duty fridedare
I am assuming it was smoking while it was running. I am guessing you need to open the back and remove the lint build up. This is a common cause of fires, because it is by the heating filiment and catches fire when running if not kept clean.
The back can usually be removed by pulling the dryer away from the wall and unscrewing six to eight screws. When you open the back, you will see the bottom of the heating element. (the rest is enclosed) The lint tends to collect near the opening of this area. Make sure you have the dryer unplugged. It could get nasty if it is not unplugged before you start messing around.
If it is making a noise while smoking, the problem could be the belt is slipping while the basket is rotating.
Feb 12, 2010 | Frigidaire FEX831CS Top Load Stacked...
Something loose between the drums
how did the underwire get there, you may want to remove lower panel please unplug washer before removing panel use a flash light there is a area were coins and other objects fall in to also have a bucket there well be water in the lower unit use something to fish it out lucky it did not get caught in pump
Nov 25, 2009 | Kenmore HE2 Plus Front Load Washer
The washer started smoking while i ws washing a load,,what could be the problem?
what did it smell like? It could of been the motor or something caught in the tub seal. Wires and so much more. we need more info.
Nov 13, 2009 | GE WSXH208A Front Load Washer
Smoke - My dishwasher was working yesterday when all of
This is a serious issue, you may need to contact the manufacturer about it. Check for recalls as your dishwasher is basically a fire hazard. There is a fan in the door that may caught fire or the door latch mechanism caught fire. Perhaps another part caught fire.
I also may recommend you to open a claim with the manufacturer about smoke damages or any other damage that your property may have.
Good luck.
Oct 05, 2009 | Hoover Dishwashers
Intermmittent buzzing noise
IT COULD BE SOMETHING CAUGHT IN THE DRUM UNPLUG THE MAINS AND OPEN THE DOOR AND TURN THE DRUM BACK AND FORWARD YOU MAY BE ABLE TOPUT THE CAUSE EASIER LIKE WORN BEARINGS SOMETHING CAUGHT IN THE HEATER OR A BRA WIRE?
May 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Help I have a ge front load dryer
ok the dryer has to be unpluged the front remove drum removed wire removed from the back before it shorts out the elemet and cost you lot more to fix
Feb 26, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
