Question about Maytag MER5775Q Electric Kitchen Range
Fridgidaire smooth top oven lock model FEF369CGSD
I wasn't using the oven but I heard this buzzing sound. I opened the oven door, heard a click which apparently was the oven lock because the lock light on the control pad started flashing. I unplugged it for the night. When I plugged it back in the buzzing had stopped but it won't unlock so I can't close the door completely and the lock light still flashes. there was also an F3 on the panel when I tried to turn the oven on.
Actually my son fixed it. The button on the face frame when the door is open, isn't just for the interior light. My son held it in and the oven latch slowly moved back to the open position. Thanks anyway
Posted on Feb 11, 2008
WHAT ARE THE ODDS! I had the exact same thing happen to my oven on the same day; I Googled the problem and there was your post with the solution! Thanxs, you saved me a bunch of headachs.
Posted on Mar 12, 2008
Remote will not work have change battery
You may need to program it. Here is how you do that, if that is not a fix then you may need a new remote.
  1. Remove key from ignition.
  2. Close all doors.
  3. Open driver side door and leave open.
  4. Perform the following steps within 24 seconds.
    a. Insert key in ignition.
    b. Turn key to ON and OFF.
    c. Repeat step b two more times.
    d. Remove key.
    e. Push driver door frame button three times (black rubber button located on driver door frame that tell the vehicle whether or not door is closed.)
5. Buzz sound, chime or doors will lock and unlock should be heard at this point signaling that the vehicle is now in
programming mode. If not, wait 40 seconds and return to step 4.
6. All transmitters need to be programmed at this time, including the old ones. Push any button on the transmitter
two times. A buzz sound, chime or doors locking and unlocking should be heard at this point signaling that the
vehicle has accepted the new transmitter code. If there is only one transmitter, repeat this step two more times
using the only transmitter. If there are two transmitters, repeat this step two more times using the second
transmitter.
7. Push driver door frame button one time. Two buzz sounds, chimes or doors locking and unlocking 2 times should
be heard at this point signaling successful programming.
Sep 20, 2012 | 2003 Mazda MPV
My Frigidaire electric range/oven started making mechanical clicking or ticking sounds all of a sudden and a "locked" light keeps flashing weakly and the going out. When I open the oven door the...
Hi mike_glenn,
Ok, do the following:
1) Press and hold the "Clear/Off" button on the oven until you hear a beep and the word "OFF" disappears from the display. The word "Lock" will remain in the display until the door lock is disengaged, which could take up to 10 to 15 seconds.
-or-
2) Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door latch to open.
I hope this helps
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 03, 2011 | Frigidaire Kitchen Ranges
The remomte control is not working after the high temperatures of yesterday With the key we can open de the doors but despite of the new batery in the remote it is nog functioning
Ok here are the programming instructions for the remote, follow them exactly, no missed steps, if this doesn't correct the issue the remote is defective most likely.
  2. Close all doors.
    d. Remove key.
transmitter.
Aug 07, 2009 | 2003 Mazda MPV
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
Self cleaning oven door lock is stuck and buzzing
you can still use the oven i would gt someone out as soon as you can to get the lock released but yes you can still use the oven
Feb 04, 2009 | Frigidaire GLEF396 Electric Kitchen Range
My electric oven will not lock the door to have it self clean
The most likely problem is that the motor that drives the locking mechanism is defective.
Mar 30, 2017 | Ovens
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Door won't open
Try holding the Off/Cancel button.
Apr 12, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag MER5775Q Electric Kitchen Range Logo
336 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
