My mp3 player turns on.the light stays green and nothing plays.i have to push thereset button to turn it off.PLEASE tell me it can be fixed.
  • Anonymous Feb 09, 2008
    My mp3 player turns on.the light stays green and nothing plays.i have to push thereset button to turn it off.They wont take it back!!!!!
Yes it can be fixed. Tack it back
Posted on Feb 09, 2008
My mp3 player will not turn on won't do any thing I've changed the battery and plugged it into my computer and it won't even turn on when I do that.
Try this solution:
Downloaded the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data",
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again. It also fixed my aac-error problem.
Sep 01, 2009 | RCA TH1602 MP3 Player
Light will come on," MP3 player" Displays and then turns off
I formatted it and re loaded music back on and now it still does the same thing so I took it back to where I got it and exchanged it
Jun 16, 2009 | Jensen SMP-115 MP3 Player
Help turning on
Push the play/pause button and hold it down for a few seconds until the light turns on. Once the light is on and solid push it again. The light will blink while it is playing songs.
Jan 05, 2009 | Coby MP-200 MP3 Player
My zen stone stays on a solid green light
Just tried this on a zen stone with speaker and worked. Connect your zen stone to your computer. When the green light is on, use a paper clip and press and hold the reset button (small hole on the headphone jack side). The green light should turn off. Wait a bit and it should start blinking to indicate it is now charging. Note: This reset only worked when I had it connected to the computer.
Hope it works for you too.
Ken
Nov 22, 2008 | Creative Labs ZEN Stone MP3 Player
My Creative Zen 4GB MP3 Player is just not turning On
I had the exact same issue and this is how i fixed it.
go to the zen website and download the latest drivers.
  1. Turn off your player.
  2. Disconnect your player from your computer.
  3. Press and hold the Play/Pause button. Continue to hold the button while you perform steps 4 and 5. If you accidentally release the button, start the procedure again.
  4. Gently push a straightened paper clip into the Reset hole.
  5. Slide the On/Off switch towards the USB port and hold until the display lights up. The Recovery Mode screen appears with four options: Clean Up, Format All, Reload Firmware, and Reboot.
  6. Select Reload Firmware, followed by Yes.
  7. Connect your player to your computer.
  8. Double-click the downloaded file and follow the instructions on the screen.
May 31, 2008 | Creative Labs Zen Micro MP3 Player
My play button wont work
The only thing I can think of is try new batteries. I know when mine plays and then shuts off by itself, the battery needs to be changed.
Hope it helps
Apr 01, 2008 | Coby MP-C883 MP3 Player
Help!!!
no but everytime i have a new battery and it is not on hold the green light just stays on
Oct 31, 2007 | RCA Lyra TH1012 MP3 Player
Sync
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Oct 14, 2007 | iLO (2 GB) MP3 Player
Going thru batteries
IF YOU FIND OUT ANYTHING ABOUT THE ZMATE, WILL YOU EMAIL ME? IM TRYING TO FIND OUT WHATS WRONG WITH MY BOYFRIEND"S ZMATE THAT I GAVE TO HIM!! THANKS!! APPRECIATE IT!! : )
Jun 01, 2007 | Dane-Elec TA-SD0512-D MP3 Player
Light stays lit and wont play
Hi, try this Download: http://www.apple.com/support/downloads/ipodresetutility102forwindows.html I had the problem that the orange and green light flashed, which meant there was an error. Nothing worked, I tried the Recover-Option in iTunes, another PC even on a Mac it didnt work. But this tool did the trick and brought my little iPod-thingy back to life.
Oct 31, 2006 | Apple iPod shuffle MP3 Player
54 people viewed this question
 Grubhead
Grubhead
