Question about D-Link DI 514 Wireless Router (DI-514)
Dinamic ip address
My internet provider says i need to set my router to except dinamic ip address. HOW do i do that?
    Novelist:
  • 173 Answers
  1. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online,
  2. Type admin for User Name, and password is blank. (do no type any thing for password.)
  3. Click OK. This logs you into the router.
  4. Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
that would fix your problem..
in case if yoy have any problem revert back with your internet service providers name.(isp).
Posted on Feb 09, 2008
Change my belkin router password want a diffrent password
Connect to the router via a cable.
Open CMD (command) prompt and type:
iconfig
you will see a default gateway listed - write the ip address down.
Open internet explorer and enter the gateway address into the address bar.
Should open a web page to configure the router.
You may have to provide a password.
If you're only interested in wireless password change, select different pages until you get to the wireless stuff.
Try this site:
http://techchannel.radioshack.com/change-security-settings-belkin-wireless-router-1402.html
How to Change Security Settings on Belkin Wireless Router
Feb 11, 2015 | Belkin Computers & Internet
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
Renew ip adress
OK. You need to reset the modem to renew ip address from the current one.You can't reset the ip address using the router reset method.So reset or switch off the modem and then switch on it.Then new dynamic ip address will assign will be generate for your connection.Check ip address using the site Ip-Details.com before and after resetting modem...I hope you will get the answer by my reply.
Jun 15, 2013 | TP-LINK Computers & Internet
How do i format my DSL2730B modem/router using a mac?
same way ...type the router address into the browser ..like this: http;??192.168.1.0 ...or whatever the router address is ...(IP) after that a page for log into setting will appear ...and to get there usually have to use the word admin for both ..user and password..Once inside the settings ..just set the router internet connection same way you set the internet directly on your computer ..if you have a modem it will be the automatic assign an ip address..in the tcp/ip protocol ..and if you have a static IP ..choose static..and manually set the IP ..sub-net mask ..default gateway ..and the dns servers just like the one provided by the ISP ..(internet service provider)
this way you set the connection to the internet of the wlan port ...
The computers will plug into the ports..and will have an automatic assign Ip address (obtain an IP address auto...set on the lan card tcp/ip protocol )..except on the manuallly configuration the IP address will be one in the range set in the router..usually in order of the p[orts..with the last digit of the IP ...in uprising order...ex..the first port IP will be 192.168.1.1 if the ip is the one I used for example earlier...and so on ...xxxxxxxxxx2 ;xxxxxxxxxx 3
the thing to remember in case you make the settings manually for the protocol ..is that the subnet mask will be 255.255.255.0 and the default gateway will be the router's IP address ..and the dns server will be the one from the provider..or if you have a modem too..will be the modem's IP address
Jul 15, 2011 | D-Link Wireless N 150 Home Router 4Port...
Buffalo router setup
You have to change the DNS servers on your PC's internet connection.
Instead of using DHCP, type in the two IP addresses from your account at dydns.com.. Right click on your connection icon and choose, "properties".. In the panel presented, choose Internet Protocol (TCP/IP) the last item in the panel. Next click 'properties' and remove the dot from "obtain IP automatically". Next, type in your new DNS server IP's. The top panel is for you PC address which has to be between 192.168.1.2 and 192.168.1.224. It doesn't matter what IP you choose as long as it is not an address used by another device). The subnet mask will fill itself in. Default gateway is 192.168.1.1. In the bottom panel fill in your new IP's. That's it.
Apr 13, 2010 | Buffalo Technology AirStation Nfiniti...
Linsky worked on Lan Line now I have Cable
Dynamic ip address is provided automatically by your internet service provider..
inorder for the linksys to work you need to remove the old configuration from the linksys.
you need to reset the router,look at back of the router you will see a hole which says reset
you need somethihg pointed like a paper clip or pin to hold it down for about 30 secs,then power off the router wiat for a minute and then power on the router,
now your linksys router should be able to take the dynamic ip address from you internet service provider.
Jan 30, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless was fine on my lan line now cable it is not?
Lets see if this works out for ya.
1. In your browser go to http://192.168.1.1
2. The user will be "admin" and the password field leave it blank
3. Go to the Setup Tab
4. On WAN Connection Type make sure it is set to "Obtain an IP Automatically"
5. Go to the DHCP tab and make sure it is enabled
6. Unplug the Roadrunner modem and the Linksys Router.
7. Wait around 15-30 seconds
8. Plug the Roadrunner modem in and wait until all the lights except the ethernet/computer connection are on.
9. When they are all on plug the Linksys router power back in
10. Wait around 30 seconds and see if your getting a connection
Otherwise get back to me. Good luck.
Cant remember how to change settings on line for my wirless netcom router!
on pc click start then type cmd in the new windows type ipconfig.. take the ip address of default gateway ( will look like 198.162.1.254 ) type it into internet explorer and there is your router web interface.
Jan 19, 2009 | NetComm NB5PLUS4W Wireless Router
Any update for l2pt protocol
Hi Milian,
Currently WRT54GX2 does not have support for L2TP connection. You may try to use WRT54GS. It has an option for L2TP connection.
Hope this helps
Oct 04, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
D-Link DI 514 Wireless Router (DI-514) Logo
70 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
