Question about Sony VAIO VGN-S150 Notebook
No power up
When start power up the lamps for Power and battery glow for a moment then still on, but the computer no power up, I cannot hear the sound of hard disk spinning, after several attempts finally the computer start to working.
Waiting for help.
Vincenzo
  • vincenzo1 Feb 10, 2008
    i try the suggestion but nothing happen -
    the problem still remain ! ! !
    vincenzo
I have same issue and it's getting worse. I hit start button, lights work but no screen, remove battery and unplug, then insert battery and try start, usually works but sometimes takes three or four times to get startup screen. System mech finds no issue, any ideas?
Posted on Jul 10, 2008
Mine does the same... sometimes after i try to turn it on over and over the screen will pop on and the vaio sign will show and off i go to my OS. if i turn off the computer it is luck to get it back on
Posted on Apr 07, 2008
  • 39 Answers
Hello Vincezo:
Try this trick...remove battery...unlplug from wall...hold the power button on and then plug into the wall.
Let me know if this works for you. If not you may be looking at a hardware failure (mainboard).
Good Luck my friend.
SeekPCRepair
Posted on Feb 09, 2008
What is the emission control system on a suzuki jimny? my emission control light came on and the jeep wont start..how could this be solved?
sorry nat, its no jeep.. (closest match here is Samurai)
moved yah i did.
No year stated, hopeless, for sure.. that...
nor is Jimny sold in USA, and this is a uSA forum.
Means we have no books on Jimny here...for that fact.
forget that lamp CEL?, it glows telling you , PCM has power and as a self test on lamp on all cars.
but the IMMO lamp? that be #1 to see... if fitted. as some are.
what matters only is this.. see how far you can get.?
won't start means nothing unless you say it cranks and don;t start.
starter motor sounds ok, not silent.?
see, we can hear this or guess. and is KEY to the reasons.
all you can do is test fuse.
see if cluster immoblizer light is glowing funny or flashing wrong.
dont crank ,? clean battery lugs, and then charge battery
jumper cable crank it.
cranks ok, check for spark.
if dont know how get tow to shop that does.
Mar 27, 2016 | Suzuki Jimny Cars & Trucks
It is not power on
if the power lamp is dead, then there is no power.
if the lamp glows, there is.
if it glows try the OSD menu, hit the monitor keys, got OSD?
no OSD is bad monitor.
good OSD?
yes !
try windoz safe mode F8, dead?
dead still?
bad monitor.
Sep 25, 2013 | HP Computers & Internet
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Laptop wont turn on
Very often this is a situation where the battery is dead and the power cord is not working. First off, check to make sure that the power cord is plugged securely in the laptop and securely in the power outlet. Is there a light glowing anywhere on the laptop? If not, you have no power going through the power cord. Check to make sure the power outlet is live. If you plug in a lamp or other device and get power, you have a bad power cord. I always keep a spare power supply cord for my portable computers. You can get them on eBay for $10 or so. When you know that your laptop is getting power through its power cord, but there is no power light glowing on your laptop, it is time to visit a computer repair shop. If the power light is glowing, but the computer will not come on, please describe what steps you are taking and what, if anything, the computer is doing.
Feb 17, 2012 | Dell Inspiron 4150 Notebook
Battery has been replaced twice once last year and again 3 weeks ago. I am still having battery problem. Whatcould be the problem as the mechanic can't seem to find the problem. Thanks.
Try this: turn everything in the car off--that means everything, all accessories, lights, etc. Remove all items in cigarette lighter sockets or power ports. Key off, car as dead as you can make it. Then take the negative battery terminal clamp off the negative post. Hook up a 12v test light between the terminal clamp and the post. If the light glows brightly, you have a parasitic drain going on which is slowly draining your battery down. The light may glow dimly to power the clock and some computer memory and that's okay. But a bright glow means a short. Now, with the lamp glowing brightly, start pulling fuses one at a time until the light goes out. The short is on one of the circuits of the last fuse pulled.
Feb 05, 2011 | 1997 Toyota Celica
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
Have an older model philips(1995)rear projection.the power light comes on green,i hear sound from the speakers,but the screen does absolutely nothing.i took the cover off and can see the lamps...
Ur tv projection lamp,when was the last time you replaced the projection lamp?Tv projection lamp was replaced last 1 1/2 or 2 years ago.The tv been on and used 4 or 5 hours a day.The tv projection lamp life it over.Require a new projection lamp.
Aug 18, 2010 | Philips Magnavox 9P6034C 60" Rear...
Glow plugs causing starting problem
if you need connectors and terminals for the glow plug connections under the valve cover, Ford sells then so you don't need a whole $600 harness.
info for your use
Section 03-07B: Glow Plug System 1996 F-250, F-350, F-Super Duty Equipped with 7.3L Diesel Engines Workshop Manual
DESCRIPTION AND OPERATION Glow Plug System The 7.3L diesel engine uses a glow plug system which preheats air in the combustion chamber to improve cold engine starting. The system consists of eight glow plugs, the glow plug control module (12B533), powertrain control module (PCM) (12A650), engine oil temperature (EOT) sensor and barometric pressure sensor (BARO sensor) (12A644). The glow plug system is electronically controlled by the powertrain control module. The powertrain control module energizes the glow plugs immediately after the key is placed in the ON position and then determines how long the glow plugs will be on according to the engine oil temperature and the barometric pressure. The required time for the glow plugs to be energized decreases as the engine oil temperature and barometric pressure increase. The glow plugs are self-regulating, and the powertrain control module controls relay ON time. The powertrain control module protects the glow plugs by energizing them for short durations if the battery voltage is abnormally high.
Possible Causes: Insufficient glow plug ON time will not allow enough heat to accumulate in the combustion chamber to easily facilitate starting. If the glow plug system ON time does not meet any of the specifications in the accompanying chart the problem is most likely a faulty wire harness connection, ground connections or glow plug relay.
If the glow plug resistance to ground is high, the most likely causes are an open UVC (under valve cover) harness or open glow plug.
Relay Operation
Install a DVOM on the glow plug feed side of the glow plug relay (large stud with two wires connected). Turn the ignition key to the ON position but do not attempt to start. Note the time in seconds from when the key is turned on and the glow plug relay energizes until the glow plug relay de-energizes. The glow plug relay makes a loud click noise which is easily heard when it energizes and de-energizes. The dome light will dim and the dash voltmeter will dip when the glow plugs are drawing current from the battery. Compare the times measured to the table (time will be affected by engine temperature, battery condition and vehicle altitude). The voltage at the glow plug feed terminal may vary from 9 to 12 volts depending upon battery condition.
If battery voltage not present check for B+ at power supply terminal (terminal with single large wire). Power for glow plug power supply is supplied from starter relay through two fusible links at solenoid.
Glow Plug Operation
Disconnect all of the glow plug/injector harness connectors from the valve cover gaskets. With the pigtail installed, measure glow plug resistance to ground (preferably B-). A resistance measurement of .1 to 6 ohms indicates a good glow plug.
Glow Plug Harness Continuity
Measure for continuity from the connector harness to the glow plug feed terminal on the glow plug relay. Resistance should be less than 5 ohms.
Incorrect measurements will result if all glow plug/injector connectors to valve cover are not disconnected.
Glow Plug Relay The glow plug relay (12A343) has a plastic base and two mounting bolts. It is operated by the powertrain control module (PCM) (12A650) which senses engine oil temperature, PCM voltage and barometric pressure. When the engine oil temperature or the barometric pressure is low, the PCM activates the glow plug relay and the glow plugs. If the PCM voltage is too high, the powertrain control module deactivates the glow plug relay and the glow plugs immediately energize for a shorter duration, decreasing the modulation of the duty cycle.
Glow Plug Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE RED-STRIPED WIRING HARNESS CARRIES 115V DC. SEVERE ELECTRICAL SHOCK MAY BE RECEIVED. DO NOT PIERCE.
    Remove valve cover (6582). Refer to Section 03-01D .
  1. Disconnect glow plug electrical connector using a pair of pliers.
  1. Remove glow plug using 10mm socket.
  1. Clean and inspect glow plug tip for damage. Replace if damaged.
Installation
  1. Install glow plug and tighten to 19 Nm (14 lb-ft).
  1. Connect glow plug electrical connector. Make sure glow plug wiring is routed to avoid moving parts.
Glow Plug Control Glow plugs are used to warm the cylinders to improve cold-engine starting. The PCM uses the engine oil temperature (EOT) sensor and barometric pressure (BARO) sensor to determine how long the glow plugs will be on. The PCM energizes the glow plugs longer if the engine is very cold or if the barometric pressure is low at high altitudes.
The PCM controls the relay that supplies power to the glow plugs with the glow plug control (GPC) signal. When the GPC signal is grounded by the PCM the relay closes, turning the glow plugs on.
The glow plugs are controlled by the following sequence:
  1. PCM energizes the glow plugs.
  1. The PCM energizes the glow plugs immediately after the ignition is placed in the ON position.
  1. The PCM then determines how long glow plugs will be on based on EOT sensor and the BARO sensor. The required time to warm up the cylinder decreases the engine oil temperature and barometric pressure increases at low altitudes.
Glow Plug Lamp Control The glow plug lamp (GPL) signal controls the WAIT TO START light located on the instrument panel. This light is used to indicate when to start the engine. The cylinders are being warmed by the glow plugs during and after this light is lit. The PCM energizes the glow plug lamp longer if the engine is very cold or if the barometric pressure is low.
When the GPL signal is brought low, the "Wait to Start" lamp is turned on.
The glow plug lamp is controlled by the following sequence:
  1. PCM lights the WAIT TO START light after a key on reset occurs.
The PCM determines the glow plug lamp activation time based on engine oil temperature, barometric pressure and battery voltage.
  1. PCM turns off the WAIT TO START light.
The glow plug lamp is turned off when the timer counts to the number of seconds specified by the PCM. The glow plugs will normally remain on longer than the "Wait to Start" lamp.
Mar 14, 2009 | 2004 Ford F350
Samsung HDTV stopped turning on and made a click sound
if it just clicks and thats it, yeah power supply. see if the fans run and it does the boot up sequence. let it try to come up again and again. it will spit out an error code. If all three LEDs on the front panel flash, it is on the engine side. Try to power up without the lamp and hold down the lamp door switch. You can see if the colorwheel is spinning or not through where the lamp shines.. you can also hear it .. its the high pitched squeel noise you hear whir up. If the colorwheel spins, then the ballast should strike up the lamp. If you hear a 1 second buzz sound, that is usually a bad lamp. The spark gap on the ballast fires if it cannot fire the lamp.. you might be able to see it glow. The lamp can be bad but not necessarily blown. If it looks good, try tightening the connections inside the assembly, the two wires (be careful fragile, glass, mercury, etc.)
Nov 23, 2008 | Samsung HLN5065W 50" Rear Projection...
Sony VAIO VGN-S150 Notebook Logo
188 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
