Question about Toshiba 62HM95 62" HDTV
Dlp vertical lines
I have a 2 year old Samsung 50" dlp tv.  I recently started having problems with vertical lines across the screen.  (e.g. lll  lll  lll  lll)  They are in sets of 3 or 4 about an inch apart, with a larger space between each set when a movie has predominately dark colors.  When the screen has mostly light colors, the lines are 1" apart across the whole screen (llllllllllll).  It looks like the colors in the lines are offset from the colors on the rest of the screen, or shifted 1".  They are there from the moment we turn it on until we turn it off, and they will not go away.  We have unplugged everything and plugged it all back in.  We have cleaned inside of the set.  It doesn't make any noises that are out of the ordinary.  We are not finding any solutions, although other people seem to be experiencing similar problems.  It isn't under warranty, which doesn't matter when no one knows what is wrong!  Samsung seems clueless on the problem.  I have a two year old 60 inch DLP wit ten groups of eight vertical black lines, several weeks ago they would go away in just a few minuets but they are on all the time now! I have removed all input signals but the lines remain. Help!!!!! The set is a Toshiba 62HM95, Thanks
    Genius:
  • 1,665 Answers
Download your manual (5.5 MB) and see troubleshooting on page 97
http://www.tacp.toshiba.com/tacpassets-images/models/62HM95/docs/62HM95_om_e.pdf
Posted on Feb 09, 2008
  • 796 Answers
Here you go....this should solve your problems...
I think your lamp is not positioned correctly in the lamp cartridge or the cartridge is not fully seated. Remove your lamp cartridge and give it good firm push when you reseat it.
    Genius:
  • 3,422 Answers
This is not a common problem. This is a vertical deflection problem - possibly a bad capacitor, bad connection, flyback/pumpup diode, or other component. If the symptoms change - particularly if they become less severe as the set warms up, a dried up electrolytic capacitor is most likely. If they get worse, it could be a bad semiconductor. Freeze spray or a heat gun may be useful in identifying the defective component.
It is often easiest to substitute a good capacitor for each electrolytic in the vertical output circuit. Look for bad connections (particularly to the deflection yoke), then consider replacing the vertical output IC or transistor(s).
Here is what I want you to do:
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
THREE: If the above does not restore the picture, then there is probably something strange going on with the horizontal deflection system. Probably one of the main Integrated Circuits that process the video and the raster generation. I doubt if it is the convergence board.
FOUR: If you are brave and want to experiment, you can go into the service mode and reset or adjust the many parameters that are available there. However, you must be very careful to record everything you adjust so you can put it back where you found it if it does not do what you wanted it to. You can enter the service mode by following the procedure in this site:
http://www.epanorama.net/links/servicemanuals.html
If the above steps i suggested doesn't solves your problem then you will have to call a technician to get it repaired.
Goodluck,
Please don't forget to rate me as fixya..
    Guru:
  • 1,894 Answers
Hello sir,
  • dewan nafees ahmed Feb 09, 2008
    its nothing but your vertical ICs..
    replace it and have a great picture..
    thank you
    good luck..
Two horizontal lines going across the screen
hi i have the same tv mine just started doing this last week were you able to fix the problem if so wht was it
Dec 02, 2012 | Samsung PN50B550T2FXZA PN50B550 50 Plasma...
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
Vertical lines
do you have a cordless phone placed nearby?
i just had that problem, and realised it was because of the phone's frequency (scary!). i move the phone/base away from the tv, and it's fine now.
Oct 10, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Apr 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Jan 17, 2008 | Televison & Video
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Toshiba 62HM95 62" HDTV Logo
451 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
