Home | Electric Fans | 3 core torpedo swi...
Electric Fans
Problem for Electric Fans
Generic problem for all Electric Fans
3 core torpedo switch, how do I wire it?
By FORGER on Feb 09, 2008
Replacing a switch how
Same Problem
Sep 17, 2008
-   im one pissed off customer-   snobunny
Sep 06, 2008
-   MY BOX FAN MODEL 3723 ALL PLASTIC BODY HARDLY USED WILL NOT TURN ON. PUT INTO WORKING WALL SOCKET ECT. HAVE DONE NOTHING SO AS NOT TO MAKE PROBLEM WORSE. CAN ANYONE HELP.
TREBLIG8@EARTHLINK.NET
-   treblig8
Feb 09, 2008
-   new 3-speed replacement switchdoes not give proper operation-   Guest
Best Solution
posted on Feb 09, 2008
Helpful)
Crossedwires
Rank: Wiz
Rating: 88%, 71 votes
BEFORE YOU PROCEED. PLEASE NOTE THAT THIS INFORMATION IS FOR TRAINING PURPOSES ONLY. USE IT AS YOU FEEL COMFORTABLE WITH. I MAKE NO GUARANTEES TO YOU OR YOUR EQUIPMENT!!
Easiest way is to follow the old switches wires. However, if that is not possible. In electric circuits, White is always neutral, green is always ground any other color could be whatever. Most likely they will be hot. PLEASE NOTE-- This is only true with electric wires. Electronic wires will be different! It is important to understand that and know which code the fan is following. Most fans will follow the electric code but you best find out first! To wire this up, you will hook the hot wire to the center contact of the switch and the wire going to power up the fan will be on the other contact. The neutral should be straight wired through, not to the switch! I would also advise going to a hardware store or store that sells electric supplies and see if they have a how to book on wiring fans etc... That would be the wisest starting point!
Was this helpful?
Yes
No
Popular Solutions for Electric Fans
Questions and Unsolved Problems for Electric Fans
Answer
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is... (More)
Answer
I have a small ? 3 litre Butterfly Elite, model IS 2347 which I've never used, and I've lost the... (More)
Answer
our electric fan stops, then run again. it is noisy and it is heating but it does not run.sometime,... (More)
Answer
We just bought & installed a Casa Vieja Probe (bronze finish) ceiling fan. All seems to be... (More)
Answer
removing glass globe from hamptom bay gossamer wind series to clean and replace bulb
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Electric Fans:
Top Electric Fan Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Electric Fan Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
