Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Everything works fine on it except it will not spray the water/ cleaning solution anymore. The suction works and the rotating brushes work. Is this fixable or is it time to invest in a new machine? Thank you in advance for the advice.
  • 27 Answers
Or run vinager through it in the tub squeeze button until vinager is emptied then run water through...then add cleaning solution and it should do the trick
Posted on Nov 13, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Buy a new solution tank. the problem might be that your not rinsing the tank with clear water after use and the soap hardens on the release button of the tank.
Posted on Feb 10, 2008
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
There is no suction on Hoover Floormate. Have cleaned everything I can see or remove
check the hose from the base to the water channel when handle is down, and see if the hose is split and open. it becomes brittle and breaks as it ages.
Apr 01, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate--Does not pick up water.
First make sure that you are getting suction from the bottom of he machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3000 floormate
H3000 Parts
Feb 07, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
My floormate spinscrubber 500 wont **** up the water anymore.
The SpinScrub 500 is model H3030. First make sure that you are getting suction from the bottom of the machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3030 floormate
H3030 Link
H3000 Link
Thanks Don't forget to give me positive feedback.
Feb 03, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate Gets little to no suction when set to both Dry and Wet Pick up.
H3000 Link
http://www.usavacuum.com/category-s/85.htm
Please give me positive feedback.
Dec 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover FloorMate won't pick water up
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
Jan 23, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I have a H3000 Floor Mat The problem is it want pick up the water after the scrub clean the floor. What could be the causeing the problem?
Hoover H3000 Floor Mat
I have a H3000 Floor Mat the problem is it won’t pick up the water after the scrub clean the floor. What could be the causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem could be that the Hoover H3000 Floor Mat could be clogged or something is blocking the suction port or you may have a pinched line of some type of which would cause it to not pickup, feel free to check with a local vacuum dealer in your area or in the yellow pages or the Hoover factory phone number is listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
771 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
