Panasonic BL-C30A Network Camera
Problem for Panasonic BL-C30A Network Camera
Cannot register 2nd BLC30a with viewnetcam.com
By blc30a on Feb 09, 2008
I got my first blc30a registered with viewnetcam OK months ago. The second one won't register and I dont know why. I have added user defined apps to my broadband modem to open the port to the one the camera needs, disabled the McAfee firewall temporarily and even end tasked on McAfee. It always says;
"failed to access test from the internet"
The camera works fine locally using ethernet cable or wireless link. Should I return it? Is the viewnetcam.com service not working?
Nigel
Comments:
Feb 09, 2008
- Additional comment: I have also switched of the Windows Firewall. Nigel
Same Problem
May 07, 2008
-   Failed to access test from the Internet. this sucks any fix?-   Guest
Apr 18, 2008
-   I have the same problem. I even use the UPnP and port forwarding but still does not work.-   kkwong
Mar 04, 2008
-   same problem-   Guest
Solution #1
posted on May 17, 2008
Not Rated)
WARMDF
Rank: Apprentice
Rating: 75%, 2 votes
RECEIVED THE FOLLOWING INFO FROM A PANASONIC REP IN TORONTO PERTAINING TO SETTING UP A SECOND CAMERA:
"THE FIRST CAMERA MUST NOT BE AT ADDRESS XXXX.XXXX.XXXX.253 (EXAMPLE 192.168.1.253). DO ONE OF THE FOLLOWING BEFORE SETTING UP THE SECOND CAMERA:
1. CHANGE THE IP ADDRESS OF THE FIRST CAMERA THROUGH STATIC SETUP (EXAMPLE 192.168.1.252)
2. DISCONNECT THE FIRST CAMERA FROM THE NETWORK PRIOR TO SETTING UP THE SECOND CAMERA. (THE FIRST CAMERA WILL GRAB A NEW ADDRESS THROUGH DHCP THE NEXT TIME IT IS CONNECTED).
THE REASON FOR DOING ONE OF THE ABOVE IS THAT THE FIRST CAMERA IS PROBABLY STILL AT AN IP ADDRESS ENDING IN 253. A NEW OR FACTORY RESET CAMERA WILL WANT TO GRAB THE SAME ADDRESS AND CAUSE AN IP CONFLICT ON YOUR NETWORK.
HOPE THIS HELPS YOU.
WARMDF
Was this helpful?
Yes
No
Popular Solutions for Panasonic BL-C30A Network
Questions and Unsolved Problems for Panasonic BL-C30A Network
Do you recommend Panasonic BL-C30A Network Camera?
Answer
Answer
Warning: This server is requesting that your username and password be sent in an insecure manner... (More)
Answer
hi im having the same problem, how can I solve it
Answer
Lost CD with Install file. DOes anyone know the location where I can download the file. Panasonic... (More)
Answer
port forwarded the port that is given by the camera Bl-C131 but still can not approach my camera.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Web Camera Experts
Top Computer & Laptop Repairmen
in , FL
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
