Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Arm won't move
When the button is pressed the opener clicks twice but does nothing. Also there is a green light on the opener that blinks four times that I have never noticed before and was wondering if this was the indicator of what was wrong but I do not have the manual to research this.
Dan
  • 504 Answers
LIFTMASTER MAKES THE CRAFTSMAN BRAND OPENER.
YOU CAN GO TO LIFTMASTER.COM AND DOWNLOAD THE MANUAL IN PDF FORMAT.
THIS WILL GIVE YOU COMPLETE DIAGNOSTICS
HOPE THIS HELPS
Posted on Jun 26, 2010
I get a 'the ink absorber is almost full' message. how do i fix it. thx in advance
1. power OFF the printer, covers closed.
2. Hold down Resume button, press and hold Power button; Green lamp will light.
3. Still holding down Power release Resume.
4. Press Resume twice, release both Power & Resume and wait until lamp stops blinking.
5. When light is steady, press Resume four times; the indicator should be green.
6. Press Resume once.
7. Press Power to reset.
Jul 02, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Keyless garage entry pad 53754 (315mHz) need to program a temparay passcode, how do I do this? thank you
1. Press the four buttons for your personal entry PIN, then press and hold the * button. The opener light will blink three times. Release the button.
2. Press the temporary 4 digit PIN you have chosen, then press ENTER. The opener will blink four times.
3. To set the number of hours this temporary PIN will work, press the number of hours (up to 255), then press *.
OR
3. To set the number of times this temporary PIN will work, press the number of time (up to 255), then press #. The opener light will blink once when the temporary PIN has been learned.
Test by pressing the four buttons for the temporary PIN, then press Enter. The door should move. If the temporary PIN was set to a certain number of openings, remember that the test has used up one opening. To clear the temporary password, repeat steps 1-3, setting the number of hours or times to 0 in step 3.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do i change the numerical code?
How to change or program code on your Craftsman Liftmaster keyless keypad made by Chamberlain.
1. Program using the "Learn" Button
2.
Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Program using the Multi-Function Door Control
NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
  1. Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
  2. While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control. Both of these should now be held down at the same time.
  3. Continue holding the ENTER and LIGHT buttons while you press the push bar on the Multi-Function Door Control (all three buttons are held).
  4. Release buttons when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Change an Existing, Known PIN
If the existing PIN is known, it may be changed by one person without using a ladder.
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  2. Press the new 4-digit PIN you have chosen, then press ENTER.
The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN, then press ENTER. The door should move.
Your new Keyless Entry must be programmed to operate your garage door opener
May 24, 2011 | liftmaster 977lm 976lm Liftmaster...
How do I change the keyless entry code to another number
How to change the code on a Chamberlain Keyless Entry Garage Door opener
How do I add, program or change a Keyless Entry PIN?
Your new Keyless Entry must be programmed to operate your garage door opener.
  1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
  2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
Change a Known, or Existing Pin/Code
The light on the motor will blink once when the PIN has been learned.
Test this by pressing the new PIN, then press ENTER. The door should then move.
I hope you find this helpful. If you need further assistance please let me know!
Have a great day! :)
Carrie
May 22, 2011 | Chamberlain Keyless Entry
How do I change the code on my outside touch pad?
  1. Press the new 4-digit PIN you have chosen, then press ENTER. The motor unit lights will blink once when the PIN has been learned.
Test by pressing the new PIN then press ENTER. The door should move.
Sep 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Green light, followed by yellow light flashes 5 times, then green again. Print screen says operator error, press printer's resume button.
Hi there
You can try not really know but it like your waste ink needs to be reset.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Wait until print head stops moving
5. Press RESUME four times (if four doesn't work try three times)
6. Press POWER once
7. Press RESUME four times (if four doesn't work try three times)
8. Press POWER once
Repeating the RESUME/POWER code twice made the difference, the fixes I found wouldn't work because they stopped at step 6.
Feb 12, 2010 | Canon I960 InkJet Photo Printer
Temporary passcode
Press the temporary 4-digit PIN you have chosen, then press Enter.
The opener light will blink four times.
To set the number of times this temporary PIN will work, press the number of times (up to 255), then press #.
Test by pressing the four buttons for the temporary PIN, then press enter. The door should move. If the temporary PIN was set to a certain number of openings, remember that the test has used up one opening. To clear the temporary password, repeat steps 1-3, setting the number of hours or times to 0 in step 3.
Oct 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
266 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
