Question about Kenmore 62622 Microwave Oven
Microwave not heating when turned on
When I put food in the microwave, it seems to be working but is only heating to lukewarm
  • Anonymous Feb 10, 2008
    Put food into the microwave turned it on a spark flew and then everything worked with the exception it did not heat up the food
    Novelist:
    Scholar:
  • 96 Answers
Well were do I start, the spark check to see if it is arking on the side panel inside, there should be a plastic cover and around it if it is black then the arking is there (this can be fix with touch up paint), meanwhile, the no heat would be cause by the bad magnetron, cap or power supply if it has one.
To see were you or going you will need to understand this is not safe, dangerous to tamper with unit,
Open the cover, at the big transformer, there will be a primery and secondary.
At the primery were two wires goes to the front were all the other wires or check to see if the voltage is present 120vac pulsing on and off when turning on the microwave, do not measure the secondery the voltage will be very high about 2k
If the voltage is present hit the big silver steal cassing at the top with a insulated tool, knowed as the magnetron to see if it will start , you will hear a mmmmm don't touch it, see if heat start inside, never leave the unit emty, put a cup of water. If it doesn't heat but the voltage is present replace the magnetron, it may also be the cap next to it,
If it has a power board after the transformer, then this would also be the problem, but I don't think you have one.
I hope this help
What About Bob
Posted on Feb 11, 2008
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont heat up food
Could be the magnatron at fault.......Cheaper to renew..
Jun 06, 2010 | Samsung MU3250W Microwave Oven
Microwave isn't heating as well as it did. After
The magnatron is weakened and needs replaced. A proper power test would tell how bad but sounds like you are beyond that already. Eric
Aug 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Microwave seems to work but does not heat food
OK, you may have a damaged thermostat or, the Magnetron may be damaged as well. you can test each device with a meter(ohm,volt).
replace any parts that dose not register.
Jun 03, 2009 | Panasonic Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Dec 14, 2007 | Frigidaire PLMV168 Microwave Oven
Kenmore 62622 Microwave Oven Logo
94 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
