Question about Motorola Mobility MD41 Expandable Handset for MD400 Series
5.8 GHZ Motorola Cordless Phone, Base w/1 additional phone
Screen reads "Out of Range" I thought the problem might be the battery pack, 3 batteries with a connecting wire. The batteries are wrapped in a green plastic or vinyl. Phone purchased 18 months ago at Sams and they do not sell the battery packs, nor does Walgreens. Thanks for your help.
  • KenStallman Feb 12, 2008
    Thanks, I went through these steps plus 2 more with the Motorola help desk and and could not get a signal back.
    Scholar:
  • 44 Answers
This is not a problem with the battery but rather the phone has lost sync. You can get it back by going to the menu screen then going to register. The phone will walk you through from there. Mine lose sync from time to time and I get the same error. I have these phones both in my shop and home.
Hope this helped you out...
Posted on Feb 09, 2008
Motorola SD4581 2.4 GHz Digital Cordless Phone won't stop chirping
Bad contact between the phone and the base unit making the pair think they are low on battery.
it probably wouldn't hurt to get some rubbing alcohol, and clean the charging contacts on the base station and the handset. Oxidation can build up, and depending on whether you normally leave the handset on the charger or not, that oxidation can interfere with the contacts.
Feb 20, 2018 | Motorola Mobility SD4581 2.4 GHz Digital...
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    Phone Not Working
    Remove the battery from the back, wait 1 minute, then replace the battery. DO NOT HIT ANY BUTTONS. place the phone back on the main base unit so it can reregister.
    Apr 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
    Handset has message Out of Range even though it is fully charged on on the handset.
    The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
    To reset the phone:
    1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
    2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
    3. Put the handset in the charge cradle.
    4. It may take up to 1 minute for the "Out of Range" to clear from the display.
    5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
    Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
    Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
    Handset can not link.
    • If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
    No dial tone
    • Check or repeat installation steps
    • Make sure the base power cord is connected to a working electrical outlet.
    • Make sure the telephone line cord is connected to the base unit and the modular phone jack?
    • Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
    • The handset might be out of range of the base. Move closer to the base.
    • Make sure the battery is properly charged (for 16 hours).
    • Ensure the battery pack is installed correctly.
    • Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
    http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
    Sep 02, 2008 | GE 26998GE1 Cordless Phone
    GE MODEL 28112 DECT 6.0 CORDLESS PHONE
    I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
    #1 - unplug the base phone
    #2 - unplug the telephone line from the base phone
    #3 - remove the battery packs from the phones
    #4 - wait 10 minutes.
    reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
    Mar 26, 2008 | GE 28112 Trio Cordless Phone
    Motorola MD761 5.8 GHz phone
    Change the channel on the base or the phones. That should fix the problem.
    Jan 21, 2008 | Motorola Mobility 5.8 GHz Digital Cordless...
    Out of range shows on main handset of cordless phone
    Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
    Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
    Phone Installation - Out Of Service
    Find the manual on the link below. Check batteries are charged preferably for a few hours then perform the reset as per the manual: To re-initialize the handset and base: 1 Disconnect the power to the base. 2 Remove the handset battery pack. 3 Wait at least 15 seconds. 4 Insert the handset battery pack. 5 Connect the power to the base. 6 Put the handset in the base to re-initialize. 7 Wait for handset to display READY (or handset name). http://telephones.att.com/docMgt/public/art/306/2255_.pdf
    Jul 28, 2007 | AT&T 2.4 GHz 2255 Cordless Phone
    Motorola MD451 phone "Out of Range?"
    Go To Menu, and Then Press Register, On The Base Than Place The Page Button On The Base.
    Jun 06, 2007 | Motorola Mobility MD451 Cordless Phone
    Open Questions:
    Motorola Mobility MD41 Expandable Handset for MD400 Series Logo
    310 people viewed this question
    Top Motorola Mobility Lands Phones Experts
    John Donghia Jr.
    John Donghia Jr.
    Level 1 Expert
    Eric Sutherland
    Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
