The ice dispenses well and regularly, however, the ice has a foul odor that makes drinking ice water unpleasant.
The ice is perfectly clear looking even though it smells bad.
The filtered water otherwise tastes fine and fresh and appears clear when tasted without the ice. about one month ago I changed the filter without any problem and it has been working fine up until now.
The ice maker recently stopped dumping dumping the ice from the tray. As a result, I turned it off for 12 hours or so, turned it on again, and it began to work again. That's when the bad ice began.
What do I do?
Ice maker will work perfectly for 3 months then stop for amonth then work for 3 monthsIce maker will work perfectly for 3 months then stop for amonth then work for 3 months
You can't post conmments that contain an email address.
In some instances when the cool water and/or ice maker is not used for some time, mold can accumulate in the tubing between the water intake and the ice maker. Once this happens, it is very difficult to eliminate. One method is to disconnect the tubing from both ends and block one end off. Then fill the tubing with bleach or half bleach and half water and let stand for just a few minutes. Then drain the bleach from the tubing and flush the tubing thoroughly. Be sure to run adequate water through the system to completely eliminate the residual odor/taste of the bleach before reconnecting.
I just replaced the water valve because my water dispenser in the door kept dripping. Google parts for your model and put in water valve. It will cost around $80 for the part. My sic year old did most of thr reacement after watching an online video.
Your model refrigerator uses an electronic Ice Maker. You can test the Ice Maker by filling with tap water and let freeze sometimes they already have ice inside and shrinking because of defrost. If you can fill the trays with tap water and it freezes and dumps but does not refill with water the problem will be the water control valve. If ice maker does nothing and on then the Ice Maker is the problem. Try that first and let me know what you find, Sea Breeze
Check to see if the dispenser has an integral water filter. If yes, replace it to improve the taste of the water. If no, then unplug and remove the top panel and shut off the water supply line to the unit.
You'll want to drain the cooling tank and clean it with some white vinegar to remove any mineral deposits that could be affecting the taste of the water. You'll want to lightly scrub the inside of the chilling/cooling tank with a mixture of at least 2/3 white vinegar and warm water to help dissolve any residue in the tank.
After you've gotten it as clean as possible, turn on the water supply line and flush the tank by filling a pitcher from the cold water dispenser. Do this for at least 2-3 gallons of water to completely clear out the vinegar mixture.
You'll also want to remove and sanitize the dispenser valves on the front of the unit, as there could be some gunk inside the spout that is adding to the foul taste and odor.
I would also suggest you install an inline charcoal water filter to the supply line serving this cooler, as that will only help improve the taste and clarity of your drinking water.
You should be able to adjust the temp of the cold water with a thermostat controler located inside the cabinent. You might want to contat Hamilton Beach to obtain an owner's manual for your unit to get more detailed information about use and operation recommendations.
Hope you found this info very helpful and best regards!
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
