Question about Intel Motherboard
Continuous Beeping, new PC
After finally getting rid of the computer I got as a high school gradpresent some 6 years ago, I went out and bought the components andbuilt myself a new PC for the first time.
Here are the specs:
Raidmax ATX568WBP Mid-Tower (PSU included with case)
Gigabyte GA-MA69GM-S2H Motherboard
AMD AM2 X2 4800+ CPU
Thermaltake fan + heatsink
MXT 300GB SATA HD
2GB (2x1G) PC6400 RAM
eVGA nVidia GeForce 8400GS PCI-e Graphics Card (has onboard graphics and sound though)
and of course a CD and DVD rom drive
So I put it all together extremely carefully, quadruple checking thateverything was in its right spot- I plug it in, turn it on, all thefans start whirring, the lights go on, no weird noises.
But! There's no beeps, it's just the sound of the fans whirring and the DVD drive powering on.
My monitor doesn't respond at all. It's plugged in, turned on,everything. The light just flashes as if it's connected but no signalis getting to it. It's not giving me the "check signal cable" dialogue,either.
I switch out my flat panel for a CRT. It does the same thing.
I test both monitors on this computer, and they work fine.
So since I can't see anything, I can't reach the BIOS or anything to even begin troubleshooting within anything.
Here's what I've tried:
* Plugging the monitor into the onboard first (VGA, then DVI) without the other GPU in.
* Plugging the monitor into the nVidia (VGA then DVI)
* Taking the RAM out and putting it in one stick at a time.
* Trying to start up without a HD connected
* Trying to start up without any IDE devices connected
* Trying to start up without a HD or IDE devices
Can anyone give me any hint to what might be wrong and what I could try in order to make it work?
Thanks in advance.
Update: Actually now, I've taken apart the whole thing and reconnected everything, now it beeps. The beeps are very fast, non stop short beeps. According to the motherboard documentation, it's telling me that I have a "power error". Which to me, that's incredibly vague... what do I do now? :(
  • 1 more comment
  • Sanaro Feb 09, 2008
    Hi Lemmor,
    I just tried again without the keyboard and mouse and there's no change.
    How do I go about checking the voltage of the battery?
    The beeps are still the same, they're too numerous to count. They're so fast they easily fit at least 2 or 3 beeps a second.
  • Ekse May 11, 2010
    Lemmors suggestion to check the battery is a waste of time please. count the beeps shorts and longs that will give me a better idea on how to help you.
  • Ekse May 11, 2010
    Details on the beeps, how many short how many fast how many total. That can tell alot.
Maybe your power supply cant handle the load? What size power supply did the tower come with?
Posted on Dec 29, 2008
  • Intel Master
  • 13,433 Answers
I checked your motherboard has a award bios. so
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running. BEEP CODE MEANING POSSIBLE CAUSE 1 Long, 2 Short Video adapter failure Bad video adapter Repeating (Endless loop) Memory error Bad memory or bad connection 1 Long, 3 Short Video adapter failure Bad video adapter or memory High freq. beeps (while running) CPU is overheating CPU fan failure Repeating High, Low beeps CPU failure Bad processor
I bolded the Repeating endless loop. Thats probably your problem. Unless its HIgh and low then its cpu.
Try removeing the memory, try it in every slot if that doesnt work you could try another memory. Or take the memory to a pc repair shop to be tested or the whole pc if you want to save your time.
If the cpu is bad, remove the heatsink and make sure the cpu is intact and looks ok, check bottom and pins also then take it to for a refund or buy a new one if you broke it. :-(
Good luck! :-)
Posted on Feb 15, 2008
  • Ekse Feb 15, 2008
    Oh my last suggestion was out of date, you have tested the memory, most likely cpu is broken?
  • 749 Answers
Hi.
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Posted on Feb 09, 2008
4 Suggested Answers
SOURCE: Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Posted on Jan 05, 2009
bsrjth
  • 270 Answers
SOURCE: Intel D865GBF Motherboard
i tink the processor have a round heasink shape whcih is in LGA 775 package .
ther will be four pin like structures on 4 corners of the hearsink . and while carefully examing u can found a notch on ecah legs . take a flat scrw driver and turn the legs in anticlok wise direction .. this will losen legs . after that hold on top pf that legs and pull slowly out each legs ......very careful whil removing intel fan
Posted on Aug 06, 2009
antiochpc
  • 1314 Answers
SOURCE: My computer turns on but nothing responds
Most likely your motherboard was DOA. Send it back for a replacement. Sounds like you've done all the troubleshooting stuff.....do double check the power supply connector...especially the P4 connector that I have occasionally forgotten to plug in...that will also cause the symptoms you describe.
Posted on Aug 14, 2009
Audi A6 Brake Light & Beeping
think its a computer system issue-its all connectd these days-even with the steering--disconnect batt then put it back after a minute-may clear up--------if not pull plug at computer clean it and replug a few times-----these reboots at times work------but u mite need to run a thuro diagnostic to see different voltages-go to a good mechanic not a dealer--a hand held scanner will not do this
Nov 11, 2013 | 2005 Audi A6 3.2
Beeping and flashing
I dropped mine and the hot wire plus side came loose inside,,,,i replaced the wire and its ok now...as for the unit its junk,,,I bought a new battery a year ago ,,,when I should have bought a new unit
Mar 22, 2013 | APC Back-UPS ES 350 - UPS ( external ) -...
We have hardly used our C2 due to continuous house moves[purchssed new in 2005/6] went to set it up today and the screen just has a series of vertical and horizontal line and then goes blank
I to have a C2 rowing machine with a PM3 moniter which i havent used since August last year, and i decided to use it to help loose the excess Christmas pounds and the moniter sounds like it does exactly the same as your moniter with the vertical and horizontal lines then goes blank. I bought the rower new about 2/3 years ago and it hasn't been used too much.
If you find a solution to the problem please let me know thanks (jm@manx.net)
James
Nov 04, 2009 | RTO Concept2 Model D Rowing Machine with...
IBM ThinkPad 600X continuous beeping
Hi...
Continuous beep usually mean problem with the memory module.
Get it checked.
Thanks
Smith
Aug 09, 2009 | IBM Computers & Internet
I have bought a lexmark fax,printer,copier X4270 two months ago and it is not working.I do not want you to call or offer me a dicount on it being repaired this is the second lexmark one that I have bought...
IF your printer is 2 months old then if not working you can contact Lexmark and get your printer replaced as its under warranty for free by the company ...
Good luck..
Aug 18, 2008 | Lexmark Office Equipment & Supplies
Continuous short beeping after RAM upgrade
Try the old ram back in if it works you have the wrong ram
ram comes in many shapes and flavours
ddr ddr2 etc
Aug 15, 2008 | Gigabyte 8IG1000MK Motherboard
Stop asking for the make and model
i'm making clarification men.. now if it easy for you to give a solution without really clearing what model that he/she has, go for it..
Jul 29, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Final spin speed
unplug unit for about 2 minutes this will reset the computer if not inside the lower front panel SHOULD BE a tech sheet this will tell you how to put it in diag. mode and will tell you whats going on with codes and this tech sheet will give you the meanings
Dec 21, 2007 | Kenmore 43142 Front Load Washer
Intel Motherboard Logo
1,669 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
