Question about Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up
  • 1 more comment
  • rolo71 Jan 15, 2009
    hotpoint tumble dryer tdc62 there is no heat an the dryer light stays on which it never did before but everything else is ok
  • stelfoxw Mar 28, 2009
    dryer light not coming on. Everything else seems ok. It started flickering off and on with loud clicking noises but now is just not lighting up.
  • Anonymous Mar 31, 2014
    Rear thermostat diagram
  • 67 Answers
Your thermostats have most likely gone they are situated at the back of the machine on top of the heater
Posted on Mar 03, 2008
Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why?
Posted on Jan 01, 2009
  • 4 Answers
The orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Your thermostats and heating elements are good (don't change these).
Posted on Apr 04, 2009
  • Peter Davey Jun 03, 2012
    Had my TCD60 for ten years, and never needed to replace that relay. BUT every 12 to 18 months one of the thermostats has failed. Doesn't matter which one, because you can only buy them as a pair so might as well replace both. They are different temperatures so be sure to note where the green spot one goes.
    Testing - when cool, both thermostats should be closed - that is, you get continuity, zero ohms. Disconnect one wire from each if unsure to avoid getting a false reading by measuring through the other circuitry.
    When you get used to it it's a ten minute job, but don't put any pressure on the heater element (as I once did with my knee working in a confined space) because it's very very fragile.
Try reading this item on ebay 140378759750, trust me it works ive just fixed my dryer in 5 mins, thought id share this as im that impressed , stu
Posted on Feb 17, 2010
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Hotpoint condencer dryer TDC62
Several reasons for it not to heat.
Obviously faulty heater, and or thermostat(s). You need meter to test. Heater and stats are located at the rear of the m/c behind a removable panel.
Faulty programmer, faulty heater relay.
Check filters etc, refer to instructions for this.
Plz leave feed back on this .
Thanks.
Posted on Dec 13, 2008
rohntech
  • 422 Answers
SOURCE: Hotpoint Ultima Condenser Dryer TDC62 - No Heat
That trouble is cause by an heater that is already open- no connectivity. Also the wire connected to it.
I hope I answer your problem.
Posted on Mar 23, 2011
cfphoenix
  • 4 Answers
SOURCE: Hotpoint TDC62
Most likely, the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Dave Duff
  • 30 Answers
I think the problem still lies with the thermal switches, they have a tendancy to corrode where the spade connector attaches to the body (see pic)
Posted on Mar 11, 2008
Mar 23, 2011 | Hotpoint Dryers
Hotpoint ultima logic sensing condencer TDC62 is not drying clothes, it doesn't appear to be heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Ive got a hotpoint tdc62 dryer and have changed the belt on it. it worked for a few seconds and now nothing any ideas?
If it was working ok before you changed the belt then i suspect a wire has come off somewhere. re trace the work you did and you hopefully will find the problem
Nov 18, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why? If you tap the machine the...
Jan 17, 2009 | Hotpoint TDC32 Electric Dryer
Thanks.
Dec 12, 2008 | Dryers
Hotpoint TDC62 condenser dryer does not heat up My hotpoint tdc62 does not heat up. I had it for approx. 5 yrs, have changed the thermostats(years) before,but have come up with a new (recent)problem. when...
Mar 11, 2008 | Dryers
Hotpoint Utima Logic Sensing Condenser TDC62
lewensc...this sounds like a classic timer issue. Before replacing it, first turn off your mains breakers and then back on. Check all wiring from the breaker panel to the unit. If okay, then have a quick look at the items in the dryer and test them using a multi tester. If nothing is amiss, replace the timer.
Dec 17, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
1,770 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
