Question about Bose 3·2·1 II System
Bose 3-2-1constantly displayed
Bose 3-2-1 constantly displayed on the unit , even when we have tried switching ot on/off the bose 3-2-1 is still displayed and we cant seem to get any operation at all from it.
  • 55 Answers
Try unplugging it for a few minutes and try again
Posted on Sep 21, 2009
Display screen led light wont come on
If the display has been gradually fading and is now unreadable, the fault is almost certainly loss of emission of the fluorescent display and it will need a replacement display module fitted (at a Bose Service Centre)
Is there any sign of characters showing in a darkened room?
If it has suddenly gone off, with all other radio features are working as normal, but prior to this the display was bright and clear, and the set has not been subjected to a fall or a sudden sharp impact of some kind, (which can crack the display module and cause it to fail) then the most likely possibilities are; a failed filament supply to the display module, a failed high tension supply rail to the display module, or loss of data feed to the display. It is also possible there may be a fault in the day/night brightness switching circuitry that has shut the display down completely. It is not possible to be more specific without seeing the unit, or even knowing which model it is I'm afraid.
Sep 04, 2014 | Bose Wave Music System CD Shelf System
System Display shows bose3-2-1
I assume your display shows Bose 321 and refuses all commands?
Your problem is not very well described. Often when something like this happens you may be able to "reset" the system by removing the AC cord from the power and after a count of 10 putting it back in. Normally the display will start with showing the Bose 123 text on the display and will subsequently go dark. After that you can switch the unit on and it should work. If it does not, call Bose, sometimes just updating the software solves this type of problem. Ask for an update disk. Normally they send that free of charge to your registered home address.
Feb 14, 2014 | Bose 3 2 1 GSX System
Bose 321 sound fading
Try the following:
1) Switch the unit off completely, using the powerswitch on the back of the bass box.
2) Switch the unit back on via de switch on the bass box.
3) The display should read BOSE 321 and than be dark.
4) Insert a CD and switch the unit on with the remote by selecting the CD/DVD mode.
5) When the sound is now OK, it means that you need to contact Bose to ask them for the latest software update for your unit. After updating your system. The problem will not reoccur.
6) in case the problem continues and at start-up using a CD, no improvement of sound is heard, the system should go into repair. Contact Bose in your country and ask for return instructions.
Jan 13, 2014 | Bose Audio Players & Recorders
Bose 321 series II giving very dull sound in all inputs. Occaisionally the sound cuts and comes back with full and bright trebble, but then cuts back to original dull sound. I cant see anything the ad
Try the following:
Jan 13, 2014 | Bose 321GS Series II System
Bose lifestyle 38 has power but will not function at all. The display reads Bose Lifestyle - Try to turn on radio and nothing happens. Tried using remote for second zone and the remote display said no...
The sub is bad.the power supply inside the sub is your problem.If your unit comes on it could also be a defective dsp pcb in the sub.everything in the sub runs the head unit.If you send to bose they have a 175. flat rate.
Feb 12, 2010 | Bose Lifestyle 38 System
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
Trying to change speakers from B & O to BOSE
All you need to do is to measure or look up the impedance of the speakers on the Beocenter 9000. Most speakers are either 4 or 8 ohms. Now measure or look up the impedance ot the Bose speakers. If the Bose speakers are the same or a lower number than the Beocenters, you are good to go. But, if the Beocenters speakers are a lower number than the Bose, then you should not switch speakers.
Nov 20, 2008 | Audio Players & Recorders
Life style error codes 801 & 802
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
DVD frozen
suggest unplug Bose system from the wall for 10 secs, then plug in and allow it to initialise.
if this fails take bose unit to dealer.
Aug 17, 2007 | Bose Lifestyle 48 System
Bose 321-GSX.
Not familiar with unit, but you can try a couple of things. Have you tried to play DVD's and CD's? If they both don't work you may have a laser problem. You can also hook up an external DVD/CD player to the coax and/or optical inputs and see if that will work. If this does, than you can still use the unit with an external source component. If that doesn't work you may need a new unit.
Jul 10, 2007 | Bose 3 2 1 GSX System
Bose 3·2·1 II System Logo
100 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
