Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Television will not come on after low voltage surge
If using the remote or manually to turn tv on, the standby light flashes 2, then 3, then 4 times. then a click as if tv shuts off. then the standby flashes 2 continuously. only unplugging set stops the continuous 2 blink.
  • 129 Answers
Good day.
Check on the horizontal output transistor, vertical transistor, and loose contacts along MICOM and system ICs.
chris
Posted on Mar 11, 2008
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    My standby/timer light is flashing and will not turn on.
    The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
    The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
    If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
    If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
    If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
    Try the following steps to check if the issue can be resolved.
    Turn off the television.
    Unplug the television power cord from the electrical outlet.
    Let the television remain without power for 60 seconds.
    Plug the power cord back into the electrical outlet.
    If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    If the issue continues to occur, service may be required.
    Thanks for using Fixya.
    Jun 02, 2011 | Sony KV-27S66 27" TV
    Standby light blinks 4 times
    Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    Standby time light on and keeps flashing
    May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
    TV turns itself off and power light flashes green
    May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
    Green light keeps blinking will not turn on at all
    May 11, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
    When i try to turn it on i get picture and sound for about 2 seconds and then it shuts off and the red light flashes,
    May 07, 2011 | Sony KDS-R50XBR1 50" HDTV
    Standby light keeps blinking but no picture
    May 01, 2011 | Sony KP-53S65 53" Rear Projection...
    Power on for 5 sec and then turn off and blinck 8 times
    May 28, 2010 | Sony KP-61HS30 TV
    Sony kp-46wt520 rear projection tv: standby light flashes
    Two things here.
    1) This is a CRT based set so there is no "lamp" involved.
    2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
    With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
    Thanks,
    Dan
    Sep 17, 2009 | Sony KP-44PX3 44" Rear Projection...
    Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
    103 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
