Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Panel light is out
We have a Jenn-Air double oven wall unit. The panel light is out and I can't read the display, but the oven and timers still work. Is there a way to replace the light?
  • 6 more comments
  • Nattitude Feb 09, 2008
    The green display has gone dim on my dual ovens & I cant really read it all the time . Does it need replacing. This is the first step Ive taken
  • Anonymous Feb 25, 2008
    oven light started fading and now is out completely.
  • jciloa Apr 19, 2008
    JennAir oven will not shut off and the lights on the display are gone.  It is 10 years old.
  • gogetit Jun 13, 2008
    Have there been any suggestions for fixes? Do we have to call a certified repairperson or can we do something to fix it ourselves?
  • gkwpnut Jun 24, 2008
    Same problem light got dim and went out. everything elase works. Took apart and saw the c3 capacitor and it looked OK. I will buy one and try it anyway. The fixitnow site says buy a new click panel for $ 169, i will go witout a light first.
  • PSU Fan Nov 06, 2008
    I can't get the panel off to change the bulb. I removed 4 screws, but the panel unit feel latched to something inside. Anyone have any ideas? I'm tempted to give it a good yank, but then I'm into a whole new oven.
  • Anonymous Nov 26, 2008
    My display panel light gradually grew dim. Now it is totally out, and Thanksgiving is tomorrow. The oven and timers still work. Help!
  • Anonymous Mar 20, 2014
    Some of the clock diigatal display lights do not light up
There is a capacitor on the clock board labelled C3. It will probably have brown burns on it or "syrup" leaking around the base. You can buy a box of 10 of these for 75 cents at Radio Shack (make sure you match the label on the old capacitor, I think it's 58mf and 35V but I could be wrong) and a pencil soldering iron for $10. It's held on with 2 little wires. Before taking it off note capacitor orientation (where the blue +++ stripe is), the replacement has to go on the same way. Common problem and easy fix.
Posted on Jun 21, 2008
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
208 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
