Question about JVC RX-618V Receiver
Left speaker channel doesn't work...speaker or headphones. Occassionally get loud hiss on left side that goes away if turn reciever off, then back on. Get headphone sound in both ears if push headphone jack only partially in headphone socket. Any ideas for self-repair? It's a Sherwood Stereo Receiver, 6/7 years old Ron
  • 13 Answers
SOURCE: TH-A35 receiver
You can't get 5.1 sound from a MP3 source !!! You get a 5.1 sound only from a good STEREO (analog) source or from a REAL 5.1 DVD audio track. Also check your "Autosurrond" setting on the remote-control.
Posted on Sep 15, 2007
SOURCE: No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Posted on Dec 29, 2007
  • 336 Answers
SOURCE: JVC RX-9010VBK receiver - premap section won't turn on normally
It sound like a bad connection. The first thing that I would do is tighten all the ground screws that hold the circiut boards and the heat sink to the chassis. If that doen't fix it, flex the circuit boards slighty to see if the relays chick on and off (disconnect the speakers first). It could be on the input board, on the relays themselves or just about anywhere.
Posted on Feb 01, 2009
Grubhead
  • 5547 Answers
SOURCE: Speaker distortion when amp is on for a couple of hours
Check out the Bias resistors in the that channel then compare with the right. You might need an Ohm meter to do it, but the resistor(s) could look burned.
Posted on Mar 25, 2009
SOURCE: JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Posted on Mar 26, 2009
Constant hissing noise from left speaker. headphone is working exellend
The headphones typically use a seperate driver than the speakers.
I don't have a PA800 schematic, but the PA500 uses a power chip part number TPA3100D2 which drives the speakers. ( That is all it really does other than mute the speakers)
IF you open your unit and find a chip with this number on it, it MAY have a problem on one of the two channels. The chip has 48 leads, and would be about 3/4 inches square. It is a dual 10 Watt switching type audio amp. Cool it with circuit cooler spray and if that changes the hiss on the channel, the chip is likely bad.
Unless you are very skilled at working with surface mounted components, you should take this for repair as special tools are required to replace it if this part is bad.
Sep 15, 2010 | Korg Pa800 Synthesizer
I have a Sanyo DCTS760 surround system. A couple of weeks ago i got a loud static noise coming from the front left speaker. I tapped gently but forcefully on the top of the reciever cabinet and this ,...
if the left front channel is not working, first test the speaker with the right channel that is working to make sure the speaker is still good.
If the speaker is good, then it means the fuse of the left channel has burnt. Open the receiver and check the left channel fuse.
Good luck.
Jul 21, 2010 | Sanyo Televison & Video
I am having the same problem with a twist, sound works from the fm and headphone but only from the right side no left audio. I have the 760 and it only has one speaker and my guess it that it gets its feed...
If you use the headphone jack a lot and your missing the audio from the speaker and one channel from the headphone jack, then it's possible that some of the headphone jack connections have broken off of the PC board. The audio goes to the speaker through the headphone jack.
Please see this link for more info and read the section about the headphone jack.
http://www.sharc.net/gps_audio_repair.htm
- Jim
Dec 19, 2009 | Garmin Nuvi 760 Car GPS Receiver
SOUND KEEP COMING IN AND OUT,LOUD HISS FROM SPEAKERS
theres a short in the wires either inside the box where the speakers are or the channels are blown.
Jun 07, 2009 | Panasonic SC-AK78 CD Shelf System
Loud hiss in bose multimedia speakers
The speakers are to close either to a printer or the monitor this due tio the model of the multimedia speaker system.
Mar 12, 2009 | Audio Players & Recorders
No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
No sound in rear speakers
I figured this one out, although I might still send it back for an exchange. It turned out that the right rear speaker works just fine, however the jack seems to be flawed. When fully plugged in, the rear speaker input only picks up the left channel. If you pull it out just a little, say 1/8-1/4 the way out it will pick up both channels. Not a good solution but it works for the time being.
Jun 03, 2008 | Razer Barracuda HP-1 Consumer Headphones
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
235 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
