Question about ASUS K8S-MX Motherboard
Overclocking failed I have been getting this msg overclocking failed . never had trouble in the past . it is under warranty kindly give solution
  • slicknessess Apr 22, 2008
    Computer won't boot until minutes after, then give a "overclocking failed" message. Tested memory to be fine, all bios settings are at default, and ran with the bare minimum hardware (hdd, 1gb ram, cpu, etc.)
  • 96 Answers
Lower you CPU clock rate to normal.
Oerclocking can cause internal components to overheat and fail.
Just hope nothing is permanently damaged...
Note; Ensure you system is VERY clean as this will aid to disapate any heat generated by overclocking.
Posted on Feb 10, 2008
Rec'd system failure msg - ink system has failed - unable to copy, or print. refer to printer documentation error Oxc18a0501 Help!
An HP technician can usually walk you through this over the phone.
If the unit is out of warranty, there will be a charge for the service.
If the ink system reset fails, they may not charge you.
In my past experience as an HP authorized technician though, this is usually the kiss of death, and the printer needs to be replaced (either by HP under warranty, or you need to buy a new one)
Feb 25, 2011 | HP Office Equipment & Supplies
Ipod touch wifi problem
Am not sure.. but try this.. it mite help ya out..
Under devices u get d name of d ipod.. right click on it n u needa check sumthin which will give u d error msg if any..
Once ya get d error msg den go to apple website n give dat error msg in d search field.. u'l find out d trouble shooting assistence..
May 01, 2010 | Apple iPod touch
Overclocking failure!!!
Pull your cooler off the processor and clean off the thermal paste and reapply. Seriously think about putting some bucks into a better way of cooling that monster if you are going to be overclocking. 185 degrees is pretty warm, you probably just baked the thermal paste, replacing it will get the cooling effects back in place.
Dec 20, 2009 | ECS 945P-A (V3.0) Motherboard
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Nov 09, 2009 | Dell Inspiron 1525 Notebook
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
Overclock procesor athlon 64 2800 +?
There are a bunch of guides out there to help you with the overclocking process.But bear in mind that you will loose your warranty as son as you change the frequency cycles. Also make sure that your system can withstand the excessive heat that will be generated by the processor.You should arrange some alternative cooling system like liquid coolers,Highgraded thermal insulation pastes or atleast a couple of additional coolant fans. Go through this.... http://www.hardwaresecrets.com/article/102
Nov 03, 2008 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Overclocking past 2.7GHz with Q6600 GO step
Please check BIOS update from mainboard manufacturer website it there has a solution for overclocking and others. Else don't push your motherboard so hard, you might get extraneous problem.
May 28, 2008 | Foxconn N68S7AA-8EKRS2H nForce 680i SLI...
Problem restrart pc /NO AUTORESTART
It sounds like you're trying to overclock your CPU, and you have exceeded what the CPU is capable of, under the current conditions. When you start the computer, enter BIOS setup (e.g. press the DEL key), and adjust the CPU settings to default. If you're not sure how to do this, choose the "LOAD OPTIMAL SETTINGS" or "LOAD DEFAULT SETTINGS" option from the main BIOS menu. If you are not getting this error until after Windows has started, then there is software installed that is trying to overclock the CPU for you. Uninstall it. It may be a program provided by Asus, or may be a third-party program. It will probably have "tweak" or "overclock" in the name. Overclocking can achieve an increase in performance, but will void the warranty, and does reduce the lifespan of the parts, and tends to make Windows crash more often. It can cause immediate failure of the parts. It should only be done if you understand and accept the risks, and have decided the reward is worthwhile. For most users, it is not worth it.
Oct 01, 2007 | ASUS P5LD2-VM Motherboard
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
ASUS K8S-MX Motherboard Logo
204 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
