Question about GE Dryers
Dryer motor replacement
I installed a new GE WE17x10010 dryer motor replacing the older WE17x32 but I don't know the correct order to reconnect the color coded wires There are 5 wires: purple,black,yellow/blackstripe,brown,violet they go to the centrifugal switch with 9 male blades numbered 1 thru 9. Are you able to tell me the proper location for these 5 wires? Many Many thanks!
What motor is in my DLB6850BALWH Dryer?
the part number for the motot is WE17X10010 and runs about $100 and if you need the repair manual that part number is WX10X116 and cost around $25
May 11, 2012 | Hotpoint NBXR463EBWW Electric Dryer
Manual for ge dryer m460-g
_ _ _ _ 4 6 0
can you fill in the blanks?
Feb 22, 2012 | GE Dryer Motor WE17X32 WE17X10010
My dryer squells through the entire cycle.
You will need to replace the dryer belt. To do this follow the instructions below
  • Disconnect the power for your dryer before beginning any work. It can be disconnected from the wall outlet.
  • 2
    Open the top of your dryer cabinet and tilt it backward.
  • 3
    Use a Phillips head screwdriver remove the top two screws. Put the screws in a safe place.
  • 4
    Tilt the front forward and roll the belt around the drum.
  • 5
    Remove the old belt by lifting the drum slightly in order to give way to the front supports. You may have to open the dryer door to help the belt fall to the bottom of the basket.
  • 6
    Position the new belt by aligning it in the correct position before beginning to thread it through the motor pulley and idler. It will take someone with strong fingers and skinny arms to be able to get past the drum in the front. The dryer belt in a General Electric dryer has to be threaded looking in from the back.
  • 7
    Reassemble your dryer by replacing the screws in the top of your dryer.
  • 8
    Close the top and slide the dryer back against the wall.
  • 9
    Reconnect the power to your dryer by plugging the cord back into the wall outlet.
  • May 02, 2011 | GE Dryers
    Dryer Model #DWXR483EG1WW turns off mid cycle (timed dry) Dryer will restart after 10 min or so but will shut off again shortly. Timer is advancing. Dryer technician suggested replacing timer. Advice?
    It sounds like the technician is clueless on this one.
    The first thing I would do is to remove the vent hose from the back of the dryer and try to run a cycle. It will heat up the room it's in but you will only need to do this once. If the dryer operates correctly you have a venting problem and need to clean the vent in your wall to make sure there are no obstructions and be careful not to kink the vent hose at all when it is reconnected.
    If this does not fix your problem there is a chance that the motor is overheating and needs to be replaced. If you need further help just let me know.
    Oct 06, 2010 | GE Dryers
    Dryer motor noisy, service call said bearing are shot in motor, replace motor is as costly as new dryer all most. Where can I order new motor best buy as neighbor can install motor( Doctor electrical...
    <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Yes, that is not that hard to fix and you can easily buy the parts yourself online...<br /><br />Here is a tip that will help you with the online buying...<br /><br />How to Buy Appliance Parts Online<br /><a href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online" target="_blank">http://www.fixya.com/support/r3907570-buy_appliance_parts_online</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
    Aug 26, 2010 | GE Profile Harmony DPGT750EC Electric...
    Dryer is not turning on. It was drying and then stopping after drying for 40 minutes and now will not turn on at all.
    The symptoms you are describing are classic of a motor failure. The motor getting weak would run for a while then overheat internally and shut down. It finally gets to a point where it shuts down and the internal windings of the motor will not reset.
    The solution would be to replace the motor, the part number is WE17X10010 for the most common one used, you would have to verify this number with the local parts supplier there for your model. The price is about $135.00 for the motor alone, to hire a technician to install would add about another $150.00 to the cost of the repair.
    I know this is not what you want to hear but unfortunately that is what is happening.
    Apr 18, 2010 | GE DBSR453EBWW Electric Dryer
    Installed new motor on GE dryer. Have power, but does not start
    There is a broken belt switch by the idler pulley. Make sure that its clicking and closing when you move the idler up and down. If the idler is out of position it will not actuate the broken belt switch and the unit wont run. You could also bypass your door switch to eliminate that as a problem. Hope this helps _MJ_
    Mar 13, 2010 | GE Dryers
    Older Ge Hotpoint Dryer will tumble but not light the gas to heat
    You state it is an older dryer, so I'd suggest replacement. The water may have damaged numerous components, including the motor, which would be costly to replace.
    Aug 28, 2009 | Hotpoint NWSR483GBWW Gas Dryer
    MOTOR
    Here's the part numbers for the motor and the substitution version, as the older one might not be available any longer. You can order this from the searspartsdirect.com website for $169.31 and it's in stock. Please verify this is the correct part for your dryer before ordering. Hope that helps! Number: WE17X0032 Substitution: WE17X10010
    Motor asm Number: WE17X0032 Substitution: WE17X10010 $169.31 In stock Quantity Add To Cart Manufacturer authorized substitution: WE17X10010 may differ in appearance, but is a functional equivalent to prior parts including WE17X0032. Manufacturer authorized substitution: WE17X10010 may differ in appearance, but is a functional equivalent to prior parts including WE17X0032.
    Jul 28, 2009 | Dryers
    Dryers Logo
    116 people viewed this question
    Top GE Dryers Experts
    Dave Harrison
    John Tripp
    John Tripp
    JP Services
    JP Services
    Are you a GE Dryer Expert? Answer questions, earn points and help others
