Question about Neff Refrigerators
Neff fridge too cold
Despite thermostat turned right down, fridge is literally freezing everything. Door is closed.
Neff have just said to me that the most probable reason is the seal not being tight enough
Posted on Nov 25, 2008
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
My fridge freezes milk and everything in it
If the fridge is freezing everything, try this before thinking it's the thermostat first turn down the temp gauge in the freezer, not fridge to about medium, still a bit to cold turn down a little more. It save me heaps
Aug 13, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Frig is 11 months old. ice is forming on vegetables in the bottom right crisper despite turning refrigerator down to 2 from 5 factory setting. this did not happen for the first 8 months. any suggestions?
Try turning freezer control to 7 and check 24 hrs.
Why ??? the freezer control is usualy the damer door control between the freezer and freshfood side... by turning the freezer up you will be closing the door to the freshfood side giving it less freezing cold air. :)
If this does not solve your problem the you will have a Thermostat control problem.
Oct 06, 2010 | GE Refrigerators
What do the three buttons mean at the top of our neff freezer
First, I'm not a Neff representative.
* Check your warranty. Call for support.https://www.neff-home.com/uk/service/support
* Website; https://www.neff-home.com/uk/products/fridges-freezers/fridges
* Manual (official - requires you to register.); https://www.neff-home.com/ie/service/manual
*** The following is for information only.***
* Model needed for specific solution.
* The buttons are for setting the coldness (harder?)
* There are some models that can change the chill "box" section to a freezer.
* Product specs (Official); https://www.neff-home.com/uk/products/fridges-freezers
* Neff Integrated Fridge Freezer K8524X8GB Product Overview (check 0:35) ; https://www.youtube.com/watch?v=NVqMz7cbY4o
* Neff K5920L0GB Side By Side American Fridge Freezer; https://www.youtube.com/watch?v=92ugO2ArjaA
* Neff KA3902B20G Side-by-side fridge-freezer; https://www.ruislipappliances.com/images/PDF/KA3902B20G.pdf
* Catalogs; http://pdf.archiexpo.com/pdf/neff-9796.html
* Products; http://www.jamesratfordbridge.co.uk/downloads/Neff_brochure.pdf
* NEFF KI2823F30G Built In Fridge;http://www.creativelivingni.co.uk/neff9.pdf
* use the posted contacts for specific support.
Aloha, ukeboy57
Jun 06, 2010 | Neff 3.80 cu. ft. / 108 liter Upright...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE GSS25LGMF side x side refrigerator. The compressor never shuts off and everything in the fridge section is freezing. Is this a thermostat problem?
it could be the damper part number WR49X10091,if the damper door isn't closing correctly cold air will just keep coming into the fridge side from the freezer,usually the damper door opens to let the cold air in when the fridge starts warming up and when it gets cold enough the door will close but your damper is stuck open
Nov 25, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerator freezes everything even on low setting
Is it a single or double door? Assuming it is a double door. Normally the upper grade models have an auger motor that opens and closes electronically depending on temperature demand. This auger situated at the top LSD of the fridge normally freezes up due to various reasons. Most common is, product is placed to close to outlet which in turn creates a blow back effect and seizes the mechanism. Need to defrost fridge section for about 2 hours for ice to melt. Retry.
If it is a single door, your thermostat needs replacement. I'm taking it you have adjusted the settings higher(not so cold) but still not correct.
Sep 27, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge won't stay cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Refrigerators
Freezer and frige not that cold
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Refrigerators Logo
583 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
