Question about HP (EK423AA) 300 GB Hard Drive
Vista will not reconize hp usb 300gb drive
I get a message
can not reconize usd device
blue power light is on and yello light constantly flickering.
A sheet with the drive says contact hp support to find avaiable updates for vista.
I found one update, but when I run it, it says I am not qualified for the update.
Hp tech usede remote desktop and they could not get it to work.
    Problem Solver:
  • 17 Answers
Some products are not compatible with vista if the product states that it does work with vista then you need to return for another one but if it does not state that it works with vista it will not work hope this hlps
Posted on Feb 09, 2008
"USB device not recognized" error message MacBook Air
The drivers must be up to date and written for your device. If there are no drivers, it will not communicate and thus it may look like it is working and in place, but the linkage is not there.
Mar 17, 2014 | Kingston DTU30G2/32GB 32GB DataTraveler...
When my computer is in sleep the blue light on my lacie turns off, and then it will flicker and then goes off again and it will continue doing this
Probably due to sleep mode. The computer will power off things such as USB ports. You can disable "Allow the computer to turn off this device to save power" under Power Management tab in Device Manager on each "USB Root Hub". Not sure if there is an equivalent on Mac
Feb 01, 2013 | LaCie Computers & Internet
Need color list for factory stereo for 99 cutlass
Constant power orange switch power ground Yellow illumination Gray dimmer Brown antenna trigger antenna pink left front + tan -gray right front + light green - dark green left rear + Brown - Yello right rear + Dark blue - Light blue
Jul 29, 2011 | Car Audio & Video
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
RE: my external hardrive
Check cmos to see if usb ports are enabled? If Windos 2000 you need a usb driver disk.
Feb 28, 2008 | Maxtor OneTouch II external hard drive...
Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Jan 30, 2008 | Seagate (ST3300601U2-RK) (ST3300601U2RK)...
POWER UP THE DRIVE AND THE DATA LIGHT BLINKS FAST CONSTANTLY
you could try to remove the drive and install it on a "USB hard drive enclosure" ( not to expensive) to see if you can get the data
it's possible your current enclosure is bad and not the drive
thanks for rating
Jan 18, 2008 | Maxtor OneTouch II external hard drive...
HP (EK423AA) 300 GB Hard Drive Logo
215 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
