Question about Virtual Reality VRCD500-SDU CD Player
I keep getting error 13 when I use my sd card. Why wont it wo
I keep getting error 13 when I use my sd card. I reformated it 3 times and it still did not work. Can U please help me?
  • selliet Feb 22, 2009
    "I keep getting error 13 when I use my usb. Why wont it play"
    Master:
    Sergeant:
  • 440 Answers
Try difernt card it may want hdcp card hi capsity 4 gb one
Posted on Feb 09, 2008
I have inserted a new sdhc 4gb card in my Dimage x 50 and have reformated but keep getting Unable to usecard
The X50 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You will need to use cards 2GB and smaller.
Jan 25, 2011 | Konica Minolta DiMAGE X50 Digital Camera
Every Time I Insert My Sd Card It Comes Up Error Volume Label Syntax And I Cant Get My Pictures On To My Computer Wat Can I Do To Get It Working Again??? Please Help Me Straight Away. Thank You xxxx
Some times Memory cards need to be reformated by the operating system you are using, so it will put a volume label when you format it, that way you won't get a syntax error.
When you plug in your memory card when your computer should recognize the Memory card just like a hard disk. That is when you need to re-format the memory card just like a hard disk. then try taking pictures then try transfering to your computer.
Dec 06, 2010 | SanDisk 4GB microSD High Capacity Memory...
Iam using lexar 2gb micro sd card and it is showing some bad sectors how to repair and recover the data in the micro sd card
Hi:
You might try formatting the card. Go to the drive and rigth click on properties and then click on tools, first try error checking the drive, a box should pop up that has two options 1. Automatically fix the system errors and 2. Scan for and attempt to recovery of bad sectors select both boxes then click start. If all goes well and windows is able to repair the device then your data is saved. If not them reformating the device is the only way to restore the device, but data on the device will be lost..
Jun 29, 2010 | Electronics - Others
My memory card for my phone says it has an unrecognized format
have you tried formatting it in your phone and in the computer
Jan 14, 2010 | SanDisk 4GB microSDHC Memory Card
My Coolpix 4600 won't work with an SD card
once you insert the card you have to go into your menu and reformat the card. reformating will erase its contents so keep that in mind.
Oct 25, 2009 | Nikon Coolpix 4600 Digital Camera
1st time set up for sd memory card on sharp xe-a203 cash register, i keep getting error code e-sd-99. i've retried it 3 times and keep getting this error. the card is 128mb.
According to my manual, the cards should be formatted on a Windows PC. Insert the card into any computer and wait for it to be recognized. Access the card's memory by clicking on the icon in the "My Computer" (or equivalent) window. BE SURE THERE IS NOTHING ON THE CARD THAT YOU WILL LOSE. This process will erase everything on the card. Right-click on the card's icon. Click "Format." Set formatting options to FAT memory. Set the allocation size to 16. Start formatting. Double-check your manual to be sure for the specifics on your exact model of calculator.
Sep 24, 2009 | Sharp Office Equipment & Supplies
Copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Jun 22, 2008 | Kodak EasyShare C330 Digital Camera
Vrcd400-sdu error code 13
CD will not go in dis slot
Jan 02, 2008 | Car Audio & Video
does your usb device use batteries,some device require.
Aug 22, 2007 | Jensen 100W x 4 Amplifier KA5 Car Audio...
IPAQ Backup on SD
Sounds like a potential problem with the SD card -- I'd try reformating the SD card and do another backup... If you still have the error, try another card...
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
Virtual Reality VRCD500-SDU CD Player Logo
400 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
