Question about Kitchen Ranges
Frigidaire electric range
FEF179FCB model # Electric Range ES340
Replaced upper heating element in oven. Trying to reset the clock for the stove to get the oven and display to work.
Upper control display does not function (clock, oven controls, etc.)
What should I do?
  • 2 more comments
  • vittorino45 Feb 27, 2008
    the lock is on but the door of the oven is open how do I get et the lock to unlock?
  • Anonymous Mar 14, 2014
    oven control panel will not work but clock is on for ge gas rang
  • Anonymous Mar 29, 2014
    oven won't heat blew a control panel and replaced it....now that doesn't work. need help troublshooting the short.
  • Anonymous Mar 30, 2014
    the clock board has been change and the oven still won't turn on....what could it be next ??
    Problem Solver:
  • 7 Answers
Is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
I replaced an element in the oven of a frigidaire model fef366emd and somehow one of the spades came off the element without my knowing, I turned it on to see if it would work and I heard an electric...
all repairs should be performed by an authorized service person.you may have blown your home electrical breaker for the range. reset the home breakers make sure you reset both breakers. high voltage ranges have dual switches.the range should work after resetting the breakers.
Jun 02, 2017 | Kitchen Ranges
No heat on range or oven
The heating element is called Magnetone.You need to replace that.
Jun 13, 2009 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Oct 07, 2008 | Frigidaire FEF364DQ Electric Kitchen Range
Electric bottom oven element, part # 31615900A, for electric range ES340, model # glef379dsd, burnt out this weekend. Bought 4/4/05. See screw from inside oven on each entrance port to rear. How do...
Just follow this link for step-by-step instructions on how to replace a heating element in an electric oven:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
This write up is for MOST electric ranges. It is a simple repair if you follow the steps. If your range configuration is different from what I have provided to you, please let me know. I hope this helps you.
Jun 30, 2008 | Frigidaire Kitchen Ranges
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
408 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
