Dot 3 oil.
HYDRAULIC CLUTCH BLEEDING
1. Clean cap. Remove reservoir cap and diaphragm. Fill reservoir and keep full throughout
procedure. Attach hose to bleed screw on actuator and submerge other end in container of
hydraulic fluid. Depress pedal slowly and hold, loosen bleed screw to purge air. Tighten bleed
screw to 18 INCH lbs. (2 N.m). Repeat as necessary until air bubbles are no longer seen.
2. Fill reservoir. Install cap and diaphragm. Start engine. Push clutch pedal to floor. Wait 9
seconds. Try to shift transaxle into Reverse. If gears grind, bleed system again.
NOTE: Hydraulic system components, which are serviced as an assembly,
have been factory-bled and filled. Bleeding is only necessary if air has
been drawn into system due to low fluid level in reservoir.
CAUTION: DO NOT use mineral or paraffin base oil in clutch hydraulic
system, or damage to rubber parts in cylinders may occur.
