Back to:
Tags:
Sony KP-65XBR10W 65 in. Rear Projection Television
Power supply
posted by GLeaAllen on Feb 09, 2008
I have a Sony KP-65xrb10w. (65" rear projection HD). I have a Sony surround receiver that is about 15 yrs old. I am using the TV’s speakers as the Center. The Center speakers quit working on all Video selections - 1,2,3, and DTV. I bought a new receiver thinking that might be the issue ( I know, I didn’t think of hooking another speaker to the center output, besides I wanted to have a switchable HDMI output). The Center still didn’t work. I took the back off the TV and was checking the connecters to the audio board. I was reconnecting the Center wires to the "Center in" clips and I think one of the wires touched a large heat dissipater (looks kinda like a radiator - is about 2x4x3 inches).
This blew a 6.3 amp fuse close on the Power Supply board. The main power supply fuse did not blow. I replaced the fuse, but now I have no power. Won’t turn on with either remote or front button. I know its drawing some current because I can hear / see some arcing in the AC outlet when I plug it in the wall outlet. I can call a repair guy, but if this is a matter of replacing a board, I can do that myself. I decided to skip using the TV speakers for the Center, unless you have a suggestion for that as well.
Thanks for any help.
Comment by GLeaAllen, posted on Feb 11, 2008
Yeah, but ptscorp.com says they can't fix this board
had it all ready to ship out, but when I called, they looked the part # up and said they couldn't fix it.
OK Thanks!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
techman
Rank:Guru Guru
Rating: 87%, 6785 votes
I thought you were going to take out the power supply board and send it out for an overhaul?
Comment by techman, posted on Feb 11, 2008
Try calling Tristate modue repair. http://www.tristatemodule.com/
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on power supply:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
Sony KP-65XBR10W 65 in. Rear Projection...
My remote control has finally gave up and I need a new...
After on for awhile the set flashes red then turns off. I...
Set will turn off and flash 8 times on diagnostic led....
want to know if I can bypass anythiny to keep a constant...
you just helped me but i went to far up. i need help to go...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
