Question about Videoseven V7 L19PS 19" LCD Monitor
V7 lcd monitor l17fm
Hi hope you can help me, reinstalled fresh copy of windows because the activation date had passed, now my monitor wont stay on light is on green but only few seconds then back to orange
4 Suggested Answers
  • 75 Answers
SOURCE: monitor black out
try to adjust the setting of your video and refresh rate
Posted on Mar 12, 2008
budmrtn
  • 11361 Answers
SOURCE: 17" lcd monitor V7
90% of LCD monitors failures are due to bad caps, as you can see in my albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Bad caps:
Posted on Apr 22, 2010
Testimonial: "thanks bro "
  • 670 Answers
SOURCE: Hi, I have a V7 L19WA - 19" widescreen monitor.
The fact that you can see a faint picture indicates that the monitor is working but the backlight circuit has a problem. The typical failures are blown transistors or bad capacitors. This can be troubleshot if you know how to unsolder and check the components with a meter. Don't know how technical you are, but if you are not, you could take to to an electronic repair service to fix. Hope this helps you.
Posted on Jan 24, 2011
V7 S20PD monitor goes blank after 1 second!
This is usually caused by one of the inverter transformers that drive the backlights, or the backlight itself. The capacitors should not be ruled out, to fix it will be expensive venture.
May 16, 2012 | V7 Computers & Internet
Windows sont run displays on sreen that i need to instal windows root system32/hal.dll and it wont start on any of the safe modes and it wont detect usb
If it cannot access any of the Advanced Boot Options, you may need to reinstall a fresh copy of the Operating System. However, try to run a hard drive diagnostic software to check if your hard drive has bad sectors.
For advanced troubleshooting on how to reinstall the file (system32/hal.dll) without doing a clean install, check the link below.
http://support.microsoft.com/kb/945380
Hope this helps.
Jun 09, 2011 | Toshiba Portege M200 Notebook
Jan 24, 2011 | Videoseven L19WA 19" LCD Monitor
There is a yellow question mark beside the video selection in Device Manager on my Windows XP computer. It starts to flicker and create lines at times but I can't seem to install a new update for the...
if your computer came with a motherboard disk the driver could be on it
control panel administrive tools computer management device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
hope this helps
Jan 12, 2011 | Videoseven V7 L19PS 19" LCD Monitor
My pc says the copy of windows is not genuine
you sould have a product key some were on your computer or on your cd case that windows came with then on xp you goto start all programs and an activation icon should be some were in there click on it and enter your key i hope this helps ps if you do not have a key you need to call microsoft
Aug 11, 2010 | Microsoft Windows XP Professional for PC
DRIVER V7 W17PS
Hi!
Try this link: http:www.driversdown.com
just type your brand and model number to find the driver for your unit.
jonags
Dec 31, 2009 | Videoseven W17PS 17" LCD Monitor
Copy of windows xp did not pass genuine windows validation
The Windows Genuine Advantage program for Windows XP uses Windows product activation, validation, and notifications to verify that your copy of Windows is genuine. Using genuine Windows delivers better performance and lets you access all downloads in the Microsoft Download Center, while helping to protect you from the risks of counterfeit software.
Activation is an anti-piracy technology designed to make sure that your copy of Windows XP is properly licensed. It works by verifying that the product key is valid and is only being used on the number of computers permitted by the software license. Activation uses a simple and fast process to protect your copy and ensure that you paid for the right thing.
Validation is a quick process that allows you to find out if the product key you activated is counterfeit or has been misused. For example, you may have accidentally received a product key that was reported as lost or stolen by its original owner. Sometimes, during a repair or reinstall, an invalid product key is used if the original product key is not handy. Microsoft values your privacy and does not use information collected during the validation process to identify you or contact you.1
Notifications helps Microsoft to fight software piracy and helps to you validate that the copy of Microsoft Windows XP that's installed on your computer is genuine and properly licensed. It reminds you that your copy of Windows XP did not pass validation and provides resources that help you to easily fix the problem online.
By confirming that your copy of Windows XP is genuine, you can take advantage of all the capabilities, support, and continuous improvements—as well as the peace of mind—that come with using genuine Windows.
If the above things wont done
Go thorugh this link WGA Validation
Hope this will helps you
Thanks & Regards
Nanda Kishore.
Jun 09, 2009 | Microsoft Windows XP Professional With...
Mother board
do you mean by xp black OS? have you let others fix your computer like reinstalling or reformatted your computer? if so, they might have used a fake windows..
Feb 06, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Monitor black out
Mar 12, 2008 | Videoseven V7 R19WPS 19" LCD Monitor
Open Questions:
Videoseven V7 L19PS 19" LCD Monitor Logo
180 people viewed this question
Top Videoseven Computers & Internet Experts
Alun Cox
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Videoseven Computer and Internet Expert? Answer questions, earn points and help others
