Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrigerator no water coming out but it makes ice
Help
  • meltob Feb 14, 2008
    i am having the same problem. Ice maker works fine though and I replaced the filter if that matters at all
  • hardrivn May 11, 2010
    I am having the same problem and plan on replacing the water switch, I checked the water tubes and they do not appear to be frozen so I am replacing the inlet valve
    http://fixitnow.com/wp/2009/01/25/no-wat...
It seems that the frozen waterline is the prevailing problem. Mine finally froze after 4 years...thank you all for your advise! I also checked to make sure that I had water to the refrigerator. I did. Instead of making a cardboard cutout for the refrigerator, I used our couch pillows and stuffed them into the freezer. They were a fast insulating fix, mold-able and a higher insulating value than the cardboard. 10 minutes with my wife's hairdryer and the problem was solved! Thank you all...
Posted on Dec 07, 2010
DOES THE ICE MAKER RECYCLE ? THERE ARE A COUPLE THINGS YOU CAN CHECK,THERE IS A TUBE THAT FILLS THE TRAY WITH WATER SOMETIMES THESE FREEZE SOLID NOT ALLOWING WATER TO FLOW TO THE TRAY YOU CAN ALSO CHECK TO MAKE SURE THE ON OFF LEVER IS IN THE PROPER POSITION
Posted on Feb 15, 2008
Sea Breeze
  • 4655 Answers
SOURCE: no water but ice is fine
Two possibilities are water solenoids on back of refrigerator.  Switch the wiring on the two solenoids so when you ask for ice it will dispense water. If you get water when you ask for ice the solenoid is bad. If still nothing happens the control switch in the door were you switch from water to ice may be bad. When you determin you have found the problem return the wires to there correct solenoids. Hope this helps, Sea Breeze
Posted on Oct 28, 2007
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
itls
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
SolutionGuy
  • 331 Answers
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Posted on Apr 01, 2009
  • 10865 Answers
SOURCE: water does not fill ice tray GE refridgerator
Hi Alice. If I was nearby I would stop by and take a look for you but since we are cyber only I will assist you and yes, you can fix this yourself!
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Aug 15, 2009
No water or ice coming from the dispenser, ice is being made. Cannot change the freezer temperature
Fix your GE refrigerator door ice and water dispenser ...
? 18:47
www.youtube.com/watch?v=8yNWbNaNCOA
Oct 20, 2013 - Uploaded by StewTube
Fix your GE refrigerator door ice and water dispenser and save ...it makes ice but no water or ice come out from the dispenserAnd if it's the ...
Oct 24, 2015 | Refrigerators
How to get ice maker to make ice.....?
check the tubing that supplies water .relocate as needed
Apr 26, 2015 | GE Refrigerators
PSS23MSTC GE PROFILE WATER WORKS, ICE CRUSHED ICE INDICATOR LIGHT DIMS NO ICE IDEAS?
clean built up ice in the door where ice comes out.....make sure the metal bar is down. its located inside the tray where the stored ice is.
Nov 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile Arctica is not making ice and not dispensing water.
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Mar 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
check to see if your on/ off switch is green on the im 1st. 2nd make sure that you have properly seeded the dispenser tray by using the cross method. the auger arm at the back of the tray turn vertical and the auger mtr gear in the rf turn horizonal then insert the tray in the machine
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
2,702 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
