Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Posted on Jan 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Everytime i turn it on the w symbol appears then the screen goes black
Anonymous
Level 2:
  • Expert 120 Answers
  • Posted on Jan 22, 2010
Anonymous
Expert
Level 2:
Answers
120
Questions
Helped
50381
Points
256
Okay this is a power issue, depending on the model of your unit what you may need to replace is ether the power board or just the inverter board. On some of the Westinhouse models the power board and the inverter board are on the same board which is called the LIPS board but this agan is only in some models. What I would recommend doing is to contact the Westinghouse parts department at [email protected] for some further information, you will need to include contact information along with model # and serial # of your unit.
When you turn on the TV it just shows the lg symbol for half a second and then the screen goes black and it turns off
Hi Anonymous,
It appears to be the backlight problem. Most probably the inverter has gone bad. May I request to kindly mention the model number of the set when you post a problem next time.
Thanks and good luck.
Acer 4650 Travelmate Black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Black screen appears
You need to reinstall the driver as Administrator, and set it for Compatability Mode for XP SP2, and see how that goes.
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Everytime i turn on my lcd tv it turns on and the pictur goes off
there are flourescent tubes inside that can be replaced, they help to alluminate the screen. There are these other boards inside that can malfunction too, best to take the unit to a technician.
The console turns on but when it gets to the staring screen it does not go through any more to the options where it has all of the icons it does not go through to the next screen. Is there a reset button...
I just held the power button (not the power swith on back of cosule)
and the screen goes black than all of the icons appear. I have to keep
on doing so everytime I turn it on>
thanks
Juan
2answers
Black snowy screen appears when camera is turned on.
just send it to a repair centre, they will repair for free. the problem could be the mainboard, and needs to be changed
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
