Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Powermate connection flickers
When pulling powermate backwards the power is intermittently goes on and off. Problem doesn't occur when pushing powermate forward... only when pulling back.
Thank you
Mike
  • 5 more comments
  • Anonymous Feb 25, 2008
    Yes, I've had the same problem with 3 of my Kenmore Progressives. 2 white models and one blue.
  • tashaktoa Apr 01, 2008
    same thing happens. I think it's the plastic connector piece to the powerhead. If I could replace that, I'd be set, but my vacuum is over 5 years old.
  • Needafix2008 May 09, 2008
    I am having similar problem with Kenmore canister vacuum flickering on and off. It's has gotten worse after a couple of weeks. Once in awhile, it completely shut off entirely. I checked the connection between the wand and the handle and it seems fine. Where else can I look?
  • zelihabt Nov 28, 2008
    the power mate power connector it doesnt stay securely in place causing it to not get power from the handle.
  • Anonymous Dec 28, 2008
    Same problem!!
  • anderson02 Feb 05, 2009
    I have a similar problem. My vacuum will shut off and/or switch power settings (carpet to low or high and vise versa). I have even turned the vacuum back ON by pushing the OFF button.
  • Anonymous Feb 06, 2009
    Same issue, but different model (orange one). Anyway it just keeps getting worse, I have taken everything apart, cleaned and put back together to no avail. Everthing looks fine. How do you take the "fuse" piece apart, I could not see a solution without breaking it?
I had the same problem. Sears has replacement parts for mine (Model 11625813506) here: http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11625813506&pop=flush
Rather than pay $10 for a new cover terminal (which I probably couldn't install myself anyway), $99 for a whole new wand, and possibly $108 for a whole new hose (ridiculous prices, btw), I took a small flat head screwdriver and scraped off the dirt/corrosion on the terminal pins. This didn't resolve my problem, but I noticed the connection between the extension wand and the "Power mate" hose handle was loose. The handle could wiggle/slide about 1/8" when connected to the wand, creating the loose connection. I used the screwdriver to bend the pins down slightly (in the direction away from the wand tube), to compensate for the loose connection. This worked like a charm, fixed the intermittent circuit contact completely, and was very easy to do. I'd highly recommend trying this, before doing anything more complicated.
Posted on Sep 17, 2009
  • 1 more comment
  • Joshua O'Rourke Nov 01, 2011
    Hello Psuedothink,
    i've been havin' the same intermittent power issue with the Powermate attachment on my Sears Kenmore canister vacuum cleaner. I used your suggestion to bend the pins away from the tube and it worked! Thanks! josh360guy 11/1/11
  • Christine Segalas Dec 01, 2011
    I too had the burned out pin and pin receptacle. Is this a common problem with Model 116? Anyway, in order to avoid paying more than necessary, I followed Pseudothink's suggestion and it worked. I'm thinking it's just a temporary fix, but for the moment I'm good with it. Thanks for your help!
  • David Stott Jul 17, 2012
    Great suggestion and solution! I originally thought I might have to replace the extension wand or rotating brush (base) unit because I thought it was a short somewhere. I had started suspecting the connection mentioned by Pseudothink, but wasn't sure. My Kenmore Progressive canister sweeper is about five years old (orange model - 116.25812508). It started noticing this problem in the last few months. Glad that such an easy thing solved the problem. In process, I also noticed a suction control dial (at that connection) that can change the intensity of the vacuum pull itself. My dial was set to the lowest pull (open), so I changed it to get greater suction. Glad to both fix the intermittent power issue and discover the suction control dial. Thanks, Pseudothink, for posting!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Your vac has the extension wand. where the wand meets the handle is where you need to check. at the top of the wand is two pins. that is a part that is call a fuse or cover terminal. you need to have that change. also check the bottom of the wand,see if there is any discoloration. there is more but if this is too much for you now, then take it to the Sears repair center.
good luck
Posted on Feb 10, 2008
I've had this problem time and again. In some cases the connectors in the hose or the wand were burned and I replaced then to correct the problem. The issue is that the dimensions of the male pins and female sockets in the connectors aren't as close as they need to be to create a tight connection. The connector at he base of the wand that attaches to the powermate head was the source of may latest frustration. After replacing the connectors, I had to shim the connecter on the powermate to force the contact pins away from the wand. It is similar to solution 2 posted above, but doesn't require bending the pins.
Posted on Jan 31, 2010
  • Kevin Smith
    Kevin Smith Jul 10, 2015
    I was able to just tin the male portion of that connector using solder paste flux and some solder. Works like a charm.
Same here...........I must admit I'm a neat freak and used this red kenmore progressive for 2 solid years 5 days a week. It took that long to start with the wand skipping with power. I couldn't tell if it was from the handle to wand or wand to powerhead connection.....either way,,, I would probably be set......But if I do get this part......How the heck do I replace it? The motors in the vacuum and powerhead work fine...........If this is a known problem, I wish Sears would do something about it...........The only reason I have went through three of them is that they are the most user friendly vacuum I've ever used and are very effective when working....... Mark40511@windstream.net
Posted on Aug 23, 2008
I had the same problem and it was getting worse for a few weeks. Then I started to smell a chemical/burning smell when I vacuumed. Then the powermate head just stopped working and I discovered that the cord on the neck of the powerhead was frayed through, it seems due the design of the cover holding it in place. I checked the parts website but you can't buy the whole powerhead. So, I now have a very expensive vacuum sculpture.
Posted on Oct 06, 2009
I by accident sucked up the corner of a sheet into the powermate of my vacuum. I turned the vacuum off and pulled out the sheet but now the powermate is no longer working (suction works fine) Is this...
These power heads have a kill switch on them. Not exactly clearly labeled.
the kill switch reset button should be on the right side of the unit as you look down like you are using it. you may want to try pushing it with the power to the power brush on. Upon resetting the button there, the power
head should start no problem.
Good luck with that.
Mark
Nov 12, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
When using the vacuum (25812) with the powermate, the power shuts off - now it just stays off. The PM Jr. works.. could this be a problem with the wand rather than the powermate unit?
Check your lower and upper wand connects for pinkish or blackened evidence of burning. All connections should be shiny clean brass. Polish with wet dry # 600 paper or a scotch abrasive dish pad.
If the junior runs, with its tighter, cleaner less used connections it is very likely the wand connections and mating component, either the hose handle or power head elbow are also burned or badly worn. On a Kenmore, due to the weight of the head and mediocre design they wear in pairs and should be replaced in pairs. You can get some electrical parts thru a Whirlpool FSP parts center or a Panasonic dealer if you take in the matching pieces for clarification
Nov 01, 2009 | Kenmore 25812 / 25813 Progressive Bagged...
Need to check belt on a Kenmore WhisperTone powermate vacuum
There are two screws. Pry off the light bar on top by pushing against the sides, and you will see them inside just behind the light bulb.
Apr 04, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
Can you tell me if Powermate Power Brush attachments are all the same for all the Sears Powermate Cannister vacuums.  That is, would one power brush attachment on a Model 116.56512690 fit one that is Model...
i think your confusing model #s ,as the 116. 22512202 is the canister model number and the model number of the powerbrush attch would be 116.52512202,but to answer your ? no it depends on which wand your useing that determans which one you can use
there 3 types of wands 1 telescoping which comes only on progressive models 2 a 2 piece with wire connected and a 2 piece
wire not connected,hope this helps,les
Jan 03, 2009 | Kenmore 22812 Bagged Canister Vacuum
Kenmore powermate front axle fell off
It will go on hard. Just angle it until you have it as far as you can go, then use maybe a hammer to knock it the rest of the way.
Jan 10, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Powermate plastic bottom broke
Go to www.sears.com, click on parts, the part you need is:
BASE-NOZLE 8191779 (4370725) 11650812007 $ 33.09 $ 33.09
You can order it thru sears online. Cost is $33.09, plus tax and shipping.
Dec 31, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
916 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
