-   my xbox 360 finds the wireless connection but has a problem with tge ip address even when i manually enter it?????????????????????????????????????????????????????????????????????????????????
-   Guest
Mar 26, 2009
-   I have the same thing happening to , IP Address failed .......HELP ME PLASE...............................HELP..........it doing my head in .........
-   xbox live + this router = fail !!
-   Guest
Dec 25, 2008
-   Ya same thing happens to me on of my friends told me that you need open the ports on your router so that it will give out a ip address to your xbox so that it will work how I'm not sure be trying to figure it out.
-   Guest
Jun 19, 2008
-   I cant get x-box live, its telling me something about an IP Address what is that-   ViNnYG194
reserve the ip address for the xbox in the router
and do port forwarding and open the xbox ports for the reserved ip
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jul 05, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Go to the network settings on the Xbox, set the ip adress to manual, you dont have to change it, run the tests, then switch it back to automatic and it should fix your problem.
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
I seemed to have lost the speed when I set up the security, is that possible or is there some other...
(More)
I seemed to have lost the speed when I set up the security, is that possible or is there some other reason. The router is a Dx Nruter model.
the wireless light isn't on and there is no wireless signal. do I have to do something to turn it...
(More)
the wireless light isn't on and there is no wireless signal. do I have to do something to turn it on?
