Question about Mitsubishi WS-55807 TV
Green crt been told center crt was leaking,arcing at line in so it needs to be replaced. recieved part # and runs about 250. My question is should I take the risk of putting a new crt in just to have it get arced out? or is that a common problem when the go bad? just trying to determin if i should cut my losses now or not
  • dakota48078 Feb 09, 2008
    the set is a 2001 watch it regularly also looks like some fluid got on boards little I cleaned it up but hate to buy a new crt plug it in and have the new one shorted out what do you think is that possible
    watch it normally I guess not long enough for this to happen lol its about a 2001 just wondering what my chances of buying the new crt and not having something short the new one out? there was a slight amount of coolant that leaked on boards but i beleive that i cleaned it all up
  • 113 Answers
It will be worth it to replace it as long as the coolant did not leak on the board. If any fluid got on the boards there is a chance your boards will be ruined. If the tube was just shorted and arcing then it just takes replacing the tube. This also will take some major convergence to get it back watchable.
Josh
Posted on Feb 09, 2008
  • 979 Answers
How old is your set and how many hours do you put on it every month? These are questions that you'll have to weigh to decide whether to keep or replace the unit...accordianman
  • Michael Borelli Feb 09, 2008
    The fluid involved is non-corrosive and usually silicone-based,.Therefore, the fact that some has gotten onto the boards is a moot point, unless some other contaminant has mixed with this substance, such as spider webbbing,(very conductive) or any other such item. In other words, don't worry about the fluid that has already spilled....accordianman
Changed crt coolant, better picture. red squiggily line starting at top center of screen, runs about a third of the way down. thought i saw scratch or small crack in green crt "c" lens. would this cau
Sounds like you may have just left one of the wires loose from the red tube. Not likely an issue from the gren tube but you can always cover the top of the lens and let just green shine up. That may help narrow it down also.
Here is more detailed info for you also.....
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 17, 2013 | Philips 60P8341 60" Rear Projection...
Do not have full 64 point convergence control on the green crt. Most all ofrt of the picture is in convergence but the top first two lines are bowed and the middle bottom line is arced in the center....
No,the tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead.Tv convergence board must be replace the 2 STK convergence ICS and also must test all of the resistors and replaces all those dead resistors too.
Mar 02, 2011 | Philips 60PP9753 60" Rear Projection...
Rca model d52w23 picture bowed, a red,blue, agreen line running across the top picture looks 3d mainly in red,blue,green
It is possible that the CRT is shorting to the convergence Yoke, pretty likely actually considering the new one lasted 15 minutes.
To fix this you must use RTV or silicone and put it all around the suction cups that are on the CRT, this is usually where the voltage develops a leak and can short out various components.
Silicone or RTV those up, then replace the fuse and see if it fires up.
If it fires up and the picture is bowed again (convergence) then you will have to replace the board again :(
The other possibility (very unlikely) is that the CRT centering is so farr off that the convergence chips have to do extra hard work to align it, this usually only happens after a CRT replacement or Yoke replacement.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2009 | Televison & Video
Green crt arcs ,no picture, sound ok
you either need a new bulb or your bulb is not installed correctly
Oct 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi WS-55809 dark scenes display green lines in background
the crt's pcbs need to be adjusted, screen control is not balanced
Nov 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
D52W20 circuit board
The center circuit board is the green CRT drive circuit. that board could be bad or the green CRT could be faulty. I have access to both those parts for your model
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Sony KP51W40 Blue tube flashes
I do not think the old tube rejuvenator will do much if the HV is arcing. The CRT it might leaking some coolant or some moisture from it is causing the arcing.
I would suggest to read the info from this website to re-seal it or replace the coolant.
Let me know if you need further assistance.
Apr 21, 2008 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi ws 55807
The green Crt for your set is part number 251C207050. You said that you cleaned up where the fluid leaked but if even the slightest is left it can and will short this board. You are looking at about 200-250 for this CRT and if it leaked you would want it replaced. I couldnt find any in stock anywhere most had feb ship dates. You can get it from andrews electronics and union electronics.
Feb 06, 2008 | Mitsubishi WS-55807 TV
Fade to Blue (same as Green Arcs?)
you can turn the Screen controls down a little bit, but I suspect you will need to replace all 3 crts as most of these crt arc sets require all 3. EXPENSIVE if crts are even still available.
May 27, 2007 | Sony KP-46WT500 46" Rear Projection...
Mitsubishi WS-55807 TV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
