How do change spark plugs on a 1998 xj8
Remove plastic cover over the engine ( three screws).
You then have access to the front three spark plugs (cylinders 1,3,5) remove the nut which holds down the independant coils and remove the spark plugs, fit new spark plugs and fit coils on the three front cylinders.
Now it gets a little tricky, you will only be able to access number 2 back cylinder so you have to remove the induction manifold (12 bolts I think) to access the back three cylinders (2,3,6,) properly.
Then proceed as with the front three spark plugs, refit manifold and plastic cover,
I have the same problems?!
