Question about Tomtom RIDER GPS Devices
Tom tom rider
Want to replace the battery on rider. Have a new battery and torx tool to remove four security nuts but still cant remove back, it seems to be held on the bottom by the conection area.
Anyone got full instructions for removing the back and replaceing battery. Answer from Buybits where I got the battery was we dont get into that,
  • wwwcd Oct 18, 2008
    Don't know if the Cylinder looking item is the battery or its deaper in the TTR1.
I made a video on how it open your TomTom rider.
Posted on Mar 15, 2009
  • gossling1 Jan 07, 2011
    very helpfull i would never have known about the two hiden screws as it just looked like part of the casing. am now a happy man
  • Pierre Allard
    Pierre Allard Mar 08, 2016
    Cannot find any battery replacement for Tom Tom Rider : Samsung 1CR 18650-22 they all have 2300mAh intead of 2200mAh what should I do ?
Yes, I have the same issue. By prizing open the case there appears to be another 2 screw lugs inside at the bottom near the existing torx screws.
From searching another forum where a user had disassembled a TomTom 300 you may have to prize off the front bezel surrounding the LCD screen. As this has been sealed with a waterproof rubber membrane it is stuck down very well.
I believe once this has been removed the 2 screws will be accessable.
Posted on Mar 21, 2008
On the rear at the bottom of the unit are 2 hidden screws hidden behind round caps.
Remove the plastic lugs with a small screw driver to reveal 2 Torx T6 screws.
Gently split the case and remove the cable running from the rear 4 pin cradle connector to the motherboard at the 3 pin socket.
Now you can replace the battery easily.
  • theofitz May 15, 2011
    Purchased 62 piece security bit from Maplin, which contains all the bits to remove the screws on my Tomtom rider, 6 screws in total. Two of the screws were to deep for the bit to reach so I gently drill the hole a little larger with a large drill bit to allow me to reach screws. Be carefull not to go too deep otherwise you may damage screw heads.
Harley Davidson 2006 FXDLI Dyna Low Rider fuse box
Hi Anonymous, on a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 11, 2012 | 2006 Harley Davidson FXDLI Dyna Low Rider
Think I blew a fuse when I was jump starting my battery. Speedometer, horn & turn signals dont work. Replaced the battery but that didn't resolve the problem. Is there a fuse box anywhere? I checked...
Hi Tucsonjohn, on a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Dec 06, 2010 | 2001 Harley Davidson FXDL Dyna Low Rider
Fuse box on 02 low rider
Hi Strange7daze, on a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Jun 14, 2010 | 2002 Harley Davidson FXDL Dyna Low Rider
How do I open the TOM TOM GO920 to change the battery?
You need to have a special tools!
Torx T7 and small flat head !
On the back of unit, using torx unscrew 2 screws!
Using small flat head screwdriver pick the front panel!
Carefully disconnect cables on the back of the display!
Unscrew circuit board!!!
Carefully disconnect speaker wire, and battery wire!!!!
Battery is glued to circuit board, carefully pill it off!!!!!!!
Place new battery on the same spot, and revert all the directions!!!!
Good Luck!!!!!!
Roman
Aug 12, 2009 | Tomtom GO 920 GPS Receiver
Tom tom 920T need to swop battery ?
Good Luck!!!!!!
Roman
Aug 07, 2009 | Tomtom GO 920 GPS Receiver
Can't remove the top to get to the motor
2 of the 4 fasteners on my Genie were TORX head screws with the little round 'blocking post' in the opening.
I acquired a set of TORX drivers which have a hollow center to accomodate these particular fasteners. (Maybe the tools came from Harbour Freight)
The REAL problem is that a new motor seems to cost 2 or 3 times the price of a new wet/dry vac.
Good luck
May 24, 2009 | Genie Company Vacuums
Pls describe the size and type of security screw on tomtom RIDER
I have tomtom rider 1.
There are 3 sizes of Torx screws; 3 sets of 2 screws each.
The largest is at the top back. I watched a fellow on YouTube take the back off. That was very helpful.
Someone called that T6 screw. I found a little set of security torx drivers for this.
The 2 bottom corner screws are smaller and then inside that on each side of the door are 2 more (smaller size but longer) screws.
Then carefully take the back off. There are wires connecting the back to the main board.
Take the card out before you try to take the back off.
Hope it works ok for you.
Ron
Mar 07, 2009 | Tomtom RIDER GPS Devices
How to replace internal battery
Remove the Front facia surround Undo four screws holding internal works to outside body You will need a T6 star screwdriver for this. Remove internal works from body at the base you will see silver foil covering feel over this you will find 4 T5 star screws securing this remove these and also remove speaker by two locating T8 star screws. Gently remove the electronic board keep all locating cables intact You will then see two T4 star screws holding battery holder remove these and the plastic holder .Unclip battery and disconnect from Pcb Board fit new battery and reassemble. .
Jan 07, 2008 | Tomtom GO 300 GPS Receiver
Tomtom RIDER GPS Devices Logo
5,732 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
