Question about EliteGroup K7S5A Pro Motherboard
Changing from the 168 pin RAM socket to the 184 pin RAM socket
Technical Support and Crucial where I bought the new 184 pin cards say all I need to do is move the jumper to change from current voltage to the required voltage. I cannot locate the jumper
  • fscott71145 Feb 09, 2008
    From reading the manual, it appears that
    it is not changing a jumper, but going into
    the BIOS settings and changing the DIMM
    Auto detect setting from "disabled" to "enabled" and then making the change to the new 184 pin cards. Am I on he right track?
  • fscott71145 Feb 10, 2008
    Problem solved. Thanks for your help.
    Genius:
  • 3,587 Answers
Will have that in one moment...stand by for manual link from taiwan
Posted on Feb 09, 2008
  • 4 more comments
  • Patrick Michaels
    Patrick Michaels Feb 09, 2008
  • Patrick Michaels
    in my experience, having the manual on hand(it's a zipped pdf document by the way) is most valuable.
    Got Backup?
  • Patrick Michaels
    oops..my bad...that's the older version..still researching..stand by.
  • Patrick Michaels
    I'm withdrawing my solution. Seems to be a raging debate among the community on this one. There are only two sets of jumper configurators on this older board. And neither of the solutions I've found, or tried myself, are applicable.
  • Patrick Michaels
    Patrick Michaels Feb 10, 2008
    I see that same information, but without the exact configuration in hand, I'd be reluctant to authorize that approach as the correct one. I spoke to Tech support from Taiwan, and they even seemed confused. At first, they suggested this is NOT an option, but when I mentioned the actual configuration settings issue, with the CMOS, they rethought it. What I'd like to know, is who originally provided the 'jumper' change informaiton, and what's their source of understanding?
    With this sort of change, it's not a good thing to guess at it. Hope this works out for you well.
    Patrick
    Got Backup?
  • Patrick Michaels
    Guru:
  • 1,894 Answers
Hello sir,
  • 2 more comments
  • dewan nafees ahmed Feb 09, 2008
    here you for the solution:
    as far as i read about your mother board i wil give the solution what i was able to arrive at.
    first what the tech support person told you to do is "move the jumper" this is actually done for clearing the CMOS set up.
    your mother board has only two kinds of jumpers. one is for hard disk. another is for clearing the CMOS.
    but with my personal experience we dint change any jumper settings for this issue. we just changed the BIOS settings.
    if at all you have to change the jumper settings and clear the BIOS i shall tell you how to do it.
    1>> remove all the main power from the mother board.
    2>> now do the necessary hardware changes
    3>> now remove the bios jumper from pin 2-3 short
    4>> now short the pins 1-2
    5>>wait for 3min
    6>> again put back the jumper in pin 2-3
    now go into the bios settings and then change the settings for new hardware changes.
    problem solved.
    wow.. you have made it..
    that is great.. that is what i said my previous post.
    thats great..
    thank you
    good luck
    cheers
    i told it out of my experience and you said it by reading the manual...
    ha ha.. great sir.. atleast now u figured out that there is no such thig to change the jumper for pin change..
    dont forget to rate the solutions..
    thank you very much
  • dewan nafees ahmed Feb 11, 2008
    thank you..
Tried to upgrade my ram modules from 512 to 2gb. also installed a new video card (for a moment... but then removed it when the problem occured). now when i power up, i get a steady...
what type of ram did you upgrade with it should have been DDR and keep the same brand/type of ram modules the same check the ram sockets make sure they are clean and the ram is securely seated The ram modules should have either of these 2 the same 1 GB 184-pin DIMM DDR PC 2700 memory module 1 GB 184-pin DIMM DDR PC 3200 memory module
Jul 01, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
Which RAM to be used in Motherboard D101GGC
1GB 184-pin DIMM
  • Module Size: 1GB
  • Package: 184-pin DIMM
  • Feature: DDR PC2700
This is taken from the Crucial memory configurator for your specific motherboard.
Go to this link for more info.
http://www.crucial.com/store/listparts.aspx?model=D101GGC
I’m happy to assist further over the phone at https://www.6ya.com/expert/walker_61ab9022a1a05bd2
Dec 22, 2010 | Intel D101GGC Motherboard
Hi. I'm trying to get ahold of a manual for the pcchips m810dlu motherboard. I need to know what capacity of rams can be stored on the board; 2700, 3200, etc. Thank you
• 2 SDRAM DIMM Sockets
- Two 184-pin 2.5V DDR SDRAM (DDR200/266) or
- Two 168-pin DIMM Socket for SDRAM memory module
• Maximum: 1GB
Aug 07, 2010 | PC Chips M810DLU (M810DLUV75C) Motherboard
Can i upgrade the memory chips so my i tunes movies will play correctly
go to www.crucial.com and click on 'scan my system'. It will tell you if you can increase the RAM.
here are the specs
2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR333/266/200)
Maximum memory : 2GB
It may be your video card, this is an old low end motherboard so it will struggle playing HD movies.
Mar 05, 2010 | PC Chips M825G Motherboard
Ram cards ?
Yes, you will have to purchase the correct RAM modules.
Your 184 pin RAM is DDR. Here is a picture.
07eb2c5.jpg If you count the small copper contacts at the bottom on this side, there are 92. There are also 92 on the other side. (Total of 184) These are the "pins".
Go to www.crucial.com and run their scan program. It is safe. It will scan your system and then tell you how much RAM you have, how much your computer will hold, and what kind of RAM you need.
Thanks for using Fixya.
Jul 01, 2009 | Televison & Video
ASUS MOTHERBOARD P4X-X CAN USE ddr 400
pls see ur specs here
http://www.baber.com/motherboards/asus/asus_p4xp-x.htm
ur board only support following RAM specs u cannot use DDR400
Memory
  • 2 x 168-pin SDR DIMM Sockets support max. 2GB PC133/PC100 non-ECC SDRAM memory
  • 2 x 184-pin DDR DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM
pls rate me FIXYA for this help if u like
Mar 13, 2009 | ASUS P4XP-X Motherboard
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
MS9317e+ manual
CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
400/533 MHz FSB Chipset SIS 651 + 961 MS9317E+
SIS 651 + 962 MS9317E+(USB)
MuTIOL® Delivering 533MB/s Bandwidth Memory Supports two 184-pin DDR DIMM maximum size up to 2GB
Supports two 168-pin SDRAM DIMM maximum size up to 2GB
Support DIMMs of DDR333/DDR266/PC133 CPUs Embedded 3D Ultra AGP VGA Support Socket 478 for Intel(R) Pentium(R) 4 1.5GHz~2.53GHz or faster Processor
Support DIMMs of DDR333/DDR266/PC133manual for this board is no longer available but above is your mobo info
Nov 01, 2008 | Matsonic MS9317E Motherboard
Memory installation
Check your manual pg. 11 section 2.5. The 168-pin RAM go in the black slots ONLY. The 184-pin RAM goes in the blue slots only. Worth a check! Luck.
Please vote.....
Jan 18, 2008 | Asrock M266A Motherboard
EliteGroup K7S5A Pro Motherboard Logo
49 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
