Question about ATI Graphic Card
Ati cga 9258atd
Trying to use tv through dvi cable-hdmi. tv just says no signal
  • Anonymous Mar 16, 2014
    CONSEGUIR LOS DRIVERS
    Scholar:
  • 45 Answers
Hi freddyboyj,
Firstly I want you to make sure that there are no damage to the connectors of your cables or on the ports on your screen card and TV, like bend or missing/dirty pins/wire connections.
Secondly make sure that the display is enabled in ATi Catalyst Control Center.
The connectors you will be using if I understand you correctly will be DVI-to-HDTV (Component video).
Follow the "click here" link at http://support.ati.com/ics/support/KBAnswer.asp?questionID=22474
for a detailed instruction set of how to connect your Screen Card to your HDTV via Catalyst Control Center.
Kind regards and thanks for using the FixYa service
Henru
Posted on Feb 11, 2008
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Im trying to use my TV as my monitor for my pc?
What problem are you having? The connection should be fairly straight forward depending on your computer's video out. You can use a VGA cable, DVI to HDMI (check your graphics card manual for single link or dual link on the DVI side), or component video (even S-video). If you have HDMI out on the video card, use an HDMI cable. If you want to connect to the TV's speakers, you need at least an 3.5 mm audio cable (or 3.5 mm to RCA audio).
The DVI cable can be either a DVI to HDMI cable or DVI to DVI or HDMI to HDMI with a DVI to HDMI adapter at one or the other end.
I hope this helps.
(you will need to go through the input modes to find the signal. Some TVs need to be on (with no signal) before the computer is turned on.)
Feb 22, 2010 | Protron PLTV-3750 Television
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
What do I need to hook it up to an hdtv...what type of cables..DVI-D to HDMI?
Your laptop will need a HDMI output or a DVI output for HD video. If your laptop only has a VGA out the your tv will need a VGA or DVI input. You could use a vga to dvi adapter if your tv does not have a vga connector. They do have a DVI to HDMI adapter but there are a couple of problems with that. One you will not get the sound and the TV will only obtain sound from HDMI cable when connected that way and Two the TV will have problems processing the signal from the computer due to the HDMI will only process the HD signals at certain formats and the computer video can send out many different signals. I tried and I could not get my tv to process the signal so I got a video card that has a HDMI out and my blu-ray player works great.
Sep 24, 2009 | Acer Aspire 3680 Laptop
HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Feb 17, 2009 | Televison & Video
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Aug 11, 2008 | Televison & Video
Computers & Internet Logo
1,559 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
