If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
check out this electric no heat tip...
There is no pilot light on that model. It uses a glowbar style igniter. It could be several things causing no heat. Here is a troubleshooting video that should help http://appliancehelponline.com/gdryertroublevideo.html
The model says electric and is listed as gas. If it is electric. Move all the settings (exercise the controls) If that does not work Turn both of the breakers off at your electric panel and back on. If one feels loose you know it may have tripped and you just reset it. Your drier will work fine now. Just turn it on.
I hope this helps U
copy n paste
http://www.partselect.com/ModelFrames.aspx?ModelID=153823&ModelNum=MDG8600AWW&ManufactureID=1&Selected=51311&Position=6&mfg=Maytag&Type=Appliance&Mark=6 let me know if this works for U "Was this helpful?"
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
Q - My gas dryer will not heat, what could stop my dryer from heating? A - Things that could stop a gas dryer from heating: - glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor. A page for checking gas dryers is here.
If it was heating occasionally after you first noticed the problem, most likely not the ignition glow element. I am having the same problem and am looking at replacing the gas valve. I used to be a Sears Repairman. I verified that both magnetic coils are energizing when they are supposed to, but often the gas won't flow. Also, I hear a clicking noise internally on the gas valve.
