Question about Compaq tc1000 Tablet PC
COMPAQ TC1000 TABET FORGOT PASSWORD
I have forgot my password for my tablet and i have tried administrator and no password it does not work i dont want to use any programs to erase the password i just want to find oout what i can do to bypass windows xp tablet edition classic login screen i have tried safe mode and i have tried ctr-alt-del twice to change it in to the welcome screen it will not let me so is there any other way
  • 4 more comments
  • Anonymous Mar 06, 2008
    I've tried the same but no luck.
  • Anonymous Apr 15, 2009
    My boyfriend has been trying to hack into his father's laptop for the past week. He needs to bypass the windows logon screen because his dad can not remember the original password. He has tried safe mode and using administrator in the user field, but nothing seems to work. We have tried to check out all websites to find some help, his last attempt so far has left him naked while trying to reduce static electricity while removing the battery, RAM, and PCI (i think that's what its called). Please please please if you know of any other way he needs the help. He doesn't want to use a downloaded program if possible.
  • Anonymous Mar 23, 2014
    I placed a pin on my tablet and I cant remember what it is and I cannot lose the info on my tablet how do I open it up ?
  • Anonymous Mar 27, 2014
    i just wanna restore my ipad2, i also have an iphone 4 with a stuck home screen and i forgot the password. ive tried everything!! the screen is a bit smashed, but most home button being stuck is the main problem... i duno what to do. pls help .. my email inspiredbylife7@gmail.com
    need to bypass password or reset irola tablet
  • Anonymous Mar 29, 2014
    Forgot my password to unlock screen on my tablet
Get better ******* answers
Posted on Mar 20, 2008
  • 24 Answers
TC1000 Password Clearing Procedure
1. Discharge any static electricity you may be carrying, it can burn up your mainboard and it doesn't take much! Remove the battery pack and place it out of immediate reach. you will be tempted to snap it back in later before it should be and this will spoil the work. Read everything before you start so you will understand. Remove the mini PCI communications/ memory expansion slot cover (2 small phillips screws, stick them to a piece of tape. When you reinstall them later, start by turning backwards till you hear and feel the threads mesh, then tighten slowly ... you don't want to strip out the threads on your frame! "Lefty loosey, righty tighty")
2. Remove the RTC battery “Real Time Clock (RTC) Battery” This is the black coated nickel sized battery tucked under the frame edge a little. You may have to remove the RAM if you have the extra slot filled to have enough room to work the RTC battery out. to remove the RAM chip pull the spring arms gently away from both sides at once and it will pop up at a 45 degree angle. pull it straight out. to reinstall it later put it back in at an angle, push it gently in then down to let the arms snap onto it and hold it in place. only goes in 1 way, note the notch. Use a toothpick to lift the black plastic film from the edge of the chip as it always tries to get in the way on reinstall. Have some patience or let someone else do it. DO NOT use any metal tools and be sure to remain static free!
Break or cut a short piece off your toothpick to make it easier to use the squared end to push and work the connector of the RTC battery plug off it's attachment. You may be able to unplug the RTC battery without removing it, your call. It connects at the white connector thats located next to the frame rail that separates the battery compartment from the mini PCI communications/ memory expansion bay. It is between (above) the battery release switch and the thumb lift depression to lift out the battery. Now, hold the power switch in the on position for 30 or 40 seconds to discharge any static. This is a good and recommended practice every once in awhile when batt is out and AC is not connected.
COMPAQ TC1000 TABET FORGOT PASSWORD - moz-screenshot-3.jpg3. Wait approximately five minutes.
4. Replace the RTC battery (or reconnect it)and reassemble the tablet PC except for the main battery, do not install it yet! Remember the toothpick will help you get the plastic film lifted clear of the RAM chip, work it into place at a 45 deg angle and then gently press it down till it locks. DO NOT STRIP out your cover screws, or try to get them super tight. They will strip out your frame, finger snug is enough.
Do not reinsert the battery pack at this time! Thats why you can't reach it!
5. Connect AC power to the tablet PC.
6. Turn on the tablet PC.
All passwords and all CMOS settings have been cleared.
7. Now you can reinstall the main Batt!
Posted on Apr 05, 2008
  • 3 Answers
There is no way to pass password screen. You can find some application to gain admin access on your laptop but they are not usually free and i do not find them safe.
Posted on Mar 11, 2008
I need to reset the bios on my Compaq TC1000. I tried removing the RTC battery and replacing as HP suggested but that didn't work, They then suggested I need to flash my bios. I cant find instructions for...
To flash the BIOS you need to download the BIOS from a link which HP provides.. so contact them and tell them to provide you with the BIOS link..
You need to download the BIOS and install it..
However after removing the RTC battery I would suggest you to hold the notebook power button for 20 secs..
This should remove all the residua power..
I think it will remove the BIOS password...
If it does not work then you could flash the BIOS..
What sayy???
Jun 25, 2010 | Compaq tc1000 Tablet PC
Where can i get the OS for the Compaq TC1000 tablet pc?
well i do have every vista version out in the markit and i can most likely install ultimate vista it has and does it all. you can contact me via email so we kan further deal with ur issue. josehanderson@aol.com
Aug 04, 2009 | Compaq tc1000 Tablet PC
I need to get into my administrator but dont know the password my laptop has trojans and many virus and the only way i can download a antivirus is to be logged into the administrator any ideas on what i...
You may be seriously stuck. You need to find someone with some serious hacking skills as a tech who can help you out.
Do any of your friends work in Computers? If not, you'll have to take it to a computer store and have them "recover your administrator password."
Jun 15, 2009 | Compaq tc4200 Tablet PC
Forgot password
There's a couple things you can do first try this:
1. This one works for some windows computers
Restart your computer and enter safe mode by pressing F8 repeatedly while the computer is starting. Once prompted hit safe mode on your screen. Once inside go to Control Panel > User Accounts > and change the password on your account or remove it.
2. This one is if all else fails
If #1 doesn't work you can use this company - www.loginrecovery.com
First download their software off the website and burn it onto a CD using Nero or another CD burning program. They have detailed instructions on the website as well as some free CD burning programs for download. Next Restart the PC and boot to the CD Drive. Next transcribe all the letters and numbers that appear on the screen to a piece of paper. Lastly enter the numbers and letters into the box on their website where you are prompted and they will tell you if the password is hackable. You can choose between free service which is 72 hours or expedited service which is $30 and 10 minutes. I've used them in the past and they work wonders for me!
Mar 05, 2009 | Compaq tc1000 Tablet PC
Memory reading
please check RAM its 256 or 512. pick up RAM & change the memory slot.
Sep 17, 2008 | Compaq tc1000 Tablet PC
Compaq TC1000 Tablet WiFi problem
You should enable adhoc mode in wireless settings.
Mar 09, 2008 | Compaq tc1000 Tablet PC
Pen Problem
Try to see if you can reinstall the driver. Also, if your computer is Vista compatible, Vista Business will install it automatically. I own a Acer Tablet and had the same problem as well.
Dec 18, 2007 | Compaq tc1000 Tablet PC
TC1000 Stopped working
Whatever happened? Fixed? still not up? Trashed?
Nov 30, 2007 | Compaq tc1000 Tablet PC
Forgot password
Forgot Windows login password? Take it easy, you can unlock forgotten password with Windows 7 Password Recovery Tool easily!
Aug 14, 2007 | Compaq D70045-236 Tablet PC
Compaq tc1000 Tablet PC Logo
731 people viewed this question
Top Compaq Tablets & eReaders Experts
Vernon Taylor
tosin_christ
alibaba69
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
