Question about Yamaha DSP-A3090 7-Channel Amplifier
Alex heya, I have a yamaha DSP-A-3090 and i have a problem with the nobs that select the input, tv, aux, vcr etc... the nobs dont proparly select the input so the picture and sound flickers whislt im watching tv. I took the cover off the amp out can't get to the nob, and anyway i dont knoe what to do. If you could help me it would me nice. thanks and have a nice day.
    Novelist:
    Champion:
  • 236 Answers
Lelex, maybe 5 years ago there must still be a solution toy our problem but right now, after more than 10years past the unit's first appearance in the market, no more parts for this. But you can still try in your area..
the problem with your DSP is the input selector switch only... very simple trouble but very hard to find a replacement. This is a top of the line model bro.... i have seen a lot use this in its first years and no porblem at all. after a year complains starts to comeup, switch problem all of them. the contacts of the mechanical switch is not that good easily gets loose. They modified after a year maybe and the replacement part was having gold plated contacts. If only you had it done in the early years then your units should still be in top condition. You can have it tried cleaned by contact cleaners but no guarranty to last maybe weeks only. sorryyy but unless you find a replacement then you are stuck with that problem.
redrivera0314@yahoo.com
I am a Yamah service Tech at Saudi Arabia before.
Posted on Mar 19, 2008
    Novelist:
    Scholar:
  • 96 Answers
Hi Lexex
Well it sound like the know what is the problem, very common on yamaha , second class unit's, mind there better then other brand that I've seen and I do prefer yamaha, I feel they take more pride in there consumer products then others big brand.
There not easy to change, you can call yamaha and order the control first to see what it looks like then know how to attack it. Some of the model they will ship the complet board you won't know until you get it.
Keep in mind there very hard to reach, you will have to take the top off, buttom off and then the intired front off just to reach the control and then replace it, I have tried to clean them but they dont' last or they cause the contract to fall apport depending on the material they used and what type of contact cleaner you have used, some or plastic frendly.... this is the one you need, you can also use brake cleaner, I find better, but they don't lubricate like contact cleaner witch has silicon lubrication in them.
I hope this help
What About Bob
Posted on Feb 12, 2008
Snes no sound
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 31, 2012 | Nintendo Super NES Console
My n 64 has audio but no video
Turn the power on.
Dec 25, 2012 | Nintendo 64 Console
Dear Sir Good morning Is the DSPA-3090 a receiver(integreted tuner )? Thank you ganesh
http://usa.yamaha.com/products/audio-visual/hifi-components/amps/dsp-a3090_black__u/?mode=model
No.
Apr 19, 2011 | Yamaha DSP-A3090 7-Channel Amplifier
Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Aug 23, 2009 | Yamaha RX-V663 Receiver
Problem with Yamaha dspA1000
Be sure you are using the AUDIO OUT on the vcr then going into a AUDIO INPUT on the DSP A1000, this will allow the DSP A1000 to amplify the audio line level.
Jan 31, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A3090: All video settings trip unit and it turns off
Hi...
Is the first set "stereo" settings and the 2nd set "surround" settings?
If so that may mean that the surround speakers arent all connected right.
Jan 14, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Can't get componet Video to work
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
Aug 10, 2007 | Yamaha HTR-5930 Receiver
No output
If the board is not cracked , check voltages at the audio output relays. on the input audio terminals side of the relays ,if you have voltage you may Have bad output Ic's
Jun 29, 2007 | Yamaha RX-V690 Receiver
Where can I buy remote control for Yamaha DSP-3090
You can get a remote for this unit from here: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DSPA3090&brand_pn=YAMAHA_DSPA3090&mode=large&uid=11819547734530
Apr 28, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
Yamaha DSP-A3090 7-Channel Amplifier Logo
210 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
