Question about Dell 1600n All-In-One Laser Printer
Clock problems The clock on the printer converts back to 05-04-2004 for some unknown reason with turned off...back on. All the other settings remain intact. Everything, for the most part, works other than this clock issue. Does the printer have an internal battery? Easy to access/change? Any suggestions???
    Genius:
  • 3,587 Answers
Hmmm..maybe it's a left over from Y2K, or Y20004?..Just kidding..The RTC(Real Time Clock) settings on most printers, are preset with a drop down date, which can be managed in the CMOS. Menu has that option, under settings. However, why it's not holding the time after turn off, is most likely a function of the CMOS battery, as you've figured out.
However, that battery is on the controller board, and is usually swapped out as part of the board replacement. I'm sure, if you open up the unit(takes a few steps), you can find a part number on that battery(should be on extreme lower left of the board). Finding an exact replacement, form, fit, and function, is another thing.
Posted on Feb 09, 2008
For some reason, in mid cycle, the machine stopped and the display now just keeps flashing with 1hr 55mins remaining on the clock. Is there anyway of resetting the system. I have tried turning it off at...
Sounds like a problem with the control panel in the washer.
Sounds like you tried what I would have suggested to begin with.
What is the brand of machine. It would help me diagnose the problem as well?
Mar 09, 2015 | Washing Machines
How I set the time on the radio?
Depends on the radio.
General idea is this:
turn radio power off on face of radio. Clock should show.
push button such as SET / CLOCK / TIME
push other button HOUR MIN up down seek scan ff rew (one button will control hour other button will control minute)
turn radio power back on. clock should remain set.
Dec 06, 2014 | 1993 Buick LeSabre
How to make the led brighter
To fix the dim brightness level, remove the battery and pull the plug out of the mains power. Leave it disconnected for at least 5 minutes then plug it back into mains power. You should find the brightness has retuned to normal. I have 3 of these Clock Radios and the picture attached shows the comparison between dim and normal. For some unknown reason they intermittently decide to dim themselves. This may be why Sony included a dimmer in the next model up ICF-C318. Anyway I hope this helps
Jan 18, 2014 | Sony ICFC218 Clock Radio
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
I recently purchased an Audiovox Clock Radio CR20 from the USA on a visit to that country. I am back in my home country India and started using the clock radio. I find that the clock is not keeping correct...
The reason of your problem is that your local mains frequency is 50 Hz and when you use 230V to 120V converter, this simple device can not convert frequency only the voltage. Your clock is synchronized to the mains frequency which is 50 Hz instead of 60 Hz and the clock goes slowly. It is late (60-50)/60 ---> 10 minutes in every hour.
I am sorry but I think your problem can not be fixed. ( It would be possible to convert the frequency but the cost of this kind of device would be higher than the value of this Audiovox)
Thanks.
gylacz
Aug 10, 2011 | Audiovox Audio Players & Recorders
HOW DO YOU SET THE CLOCK ON THE DEP-P4000UB
STEP ONE (PRELIMINARY): With the key in the ignition, turn the ignition to ACC (accessory power) or this can be done while the vehicle is running. If unit remains off, proceed to the next step, but if unit is already powered on, power it down by pressing [Source] until it goes off. (Then, proceed to the next step.)
STEP TWO: Press MULT-CONTROL & hold until CLOCK SET displays. (To cancel at any time, press [Band/ESC]. Press [Back] to return to previous display.)
STEP THREE: Press MULTI-CONTROL to select the desired segment of the clock display to set. Each time MULTI-CONTROL is pressed, it selects (blinks) one clock display segment: Hour - Minute.
STEP FOUR: Turn (or push) MULTI-CONTROL (up/down) to change the clock display segment setting.
Apr 10, 2011 | Pioneer Car Audio & Video
Since DST started I cannot get my radio controlled clock to reset to the actual time. I replaced the battery and now the clock will set itself four hours from the time it stopped, then stop again. i have...
take the batteries back out and leave them out for at least 2 minutes. next put the batteries back in and put the clock near a wall or window so that the back of the clock faces colorado (where the WMV transmitter is),. It will most likely take all night for it to set properly, just after you put in the battery make sure that you have set your time zone on the back of the clock and if there is DST button press that too. just be patient, it will set itself. worse comes to worse you can set it by hand, but kind of defeats the purpose of having an "atomic clock". by the way the reason they call it "atomic" is becausee WMV's clock is tracking the decay of the Seisum atom, or some such bs.
Mar 17, 2011 | Seth Thomas Radio-Controlled Howard Wall...
Mechanical Pool Pump timer. The clock is not working. I can turn my pump on manually but when I set the time the clock remains at the same time and does not move.
The timer wiring provides power for the clock itself. If it is incorrectly wired or if the clock is not working, the pump will not turn on.
Gary
Mar 01, 2011 | Intermatic T104 24h 208-277v Mechanical...
Clock is on but won't keep the time
You may have a problem with the lithium battery. They have a three year shelf life and sometimes power surges or outages will reduce the life of the battery. You can try replacing the battery and see if the clock returns to normal operation.The battery type is a CR2430. This battery is sold at most electronic stores and some large drugstores and supermarkets. Fry's Electronics and Radio Shack carry them. If this does not fix the problem you may want to contact Emerson customer support at this telephone number 1-800-898-9020. Give them the model number of your clock radio and the problem you are having with the clock. I hope this information help you with your Problem.
Mar 16, 2009 | Emerson Smartset Clock Radio
Dell 1600n All-In-One Laser Printer Logo
101 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
